C Drive Overload
2018-07-10T19:08:17+00:00
I have been having problems with my C drive on my laptop. It has been overloaded for sometime and I am needing some assistance as to what I can do to get it back to normal. I have tried to optimize, and that doesn't seem to work and I don't want to delete anything. What can I do?
DaveM121 935.1K Reputation points Independent Advisor
2018-07-11T19:23:49+00:00
Hi Jason, yes a lot of stuff - 3/4 of your hard drive was in that folder, you will have a lot of free space once that is done
Make sure to empty your Recycle Bin once that is done . . .
46 additional answers
  1. DaveM121 935.1K Reputation points Independent Advisor
    2018-07-11T17:15:26+00:00
    Hi Jason, if you type some taxt, like here is the screenshot and then add the screenshots, does Community then accept that - perhaps there is a problem on this forum at the moment - it happens a lot . . .
    2018-07-11T17:17:03+00:00
    Here is the screen shot
  3. DaveM121 935.1K Reputation points Independent Advisor
    2018-07-11T17:23:06+00:00
    hi Jason thanks, that came through
    Most of your date (700GB) is some folder beginning with N and 145GB id in a fodler beginning with U - I cannot see the name on those folders . . .
    Expand that TreeSize window
    1.
    Click and drag the top of the name column to the right so I can see the names on those folders
    2 & 3
    You should also dig down into those folders to find the actual folder that contains all that data . . .
    Then please provide another screenshot . . .
    2018-07-11T17:26:32+00:00
    Snip Screenshot #2
