C Drive Overload
2018-07-10T19:08:17+00:00
I have been having problems with my C drive on my laptop. It has been overloaded for sometime and I am needing some assistance as to what I can do to get it back to normal. I have tried to optimize, and that doesn't seem to work and I don't want to delete anything. What can I do?
DaveM121 935.1K Reputation points Independent Advisor
2018-07-11T19:23:49+00:00
Hi Jason, yes a lot of stuff - 3/4 of your hard drive was in that folder, you will have a lot of free space once that is done
Make sure to empty your Recycle Bin once that is done . . .
46 additional answers
    2018-07-11T15:54:36+00:00
    This thing is not allowing me to send a picture at all. And I am really getting frustrated with this
  2. DaveM121 935.1K Reputation points Independent Advisor
    2018-07-11T15:57:08+00:00
    Hi Jason
    How to add a screenshot . . .
    Click your Start Button, type snip and hit Enter - this will open the Snipping Tool
    Set Mode to Full Screen, then click New to take a screenshot
    Save that file to your Desktop and close the Snipping Tool
    Then in your next Post, click the second last button on the toolbar above your post to select that image and upload it to your post . . ..
    2018-07-11T16:01:24+00:00
    Ok thanks. I will do that after I get back from lunch
    2018-07-11T17:13:21+00:00
    Message must contain a minimum of 6 characters
    This error message keeps showing up every time I try to press the Reply button to send it to you
