how to fix Sihost.exe-systems warning hard error not known windows 10
2018-04-22T08:23:03+00:00
hello does anyone know how to fix Sihost.exe- systems warning  hard error unknown in windows 10 I can not open pc other than safe command prompts but tend to use safe command prompt or command prompt due to other seem to lock up
happen when downloading sound driver update
    2018-05-21T14:49:24+00:00
    This was first screen but none of the icons are operational. If you click on ok it will start acting like an update but then goes to a black screen with inop mouse. Then the next pic i will post
    2018-05-21T12:44:47+00:00
    I have error 50 with the second line to restore health. My issues started yesterday during Windows 10 update.
  3. Deleted
    2018-05-21T10:27:48+00:00
    Hi DaveM121,
    I got the same error, but after verification, c:/ tell me that "windows resource protection could not perform the requested operation"
    What can i do?
    The command  "Dism / online/ cleanup-image /restorehealth" give me an error 87
  5. DaveM121 933.9K Reputation points Independent Advisor
    2018-04-22T08:46:17+00:00
    Hi Mr, Sihost.exe is the Shell Infrastructure Host, which is a Windows System File
    Can you get into Command Prompt?
    If so, run these commands, one at a time and hit Enter after each one:
    sfc /scannow
    dism /online /cleanup-image /restorehealth
    Hopefully this will repair your Windows System files . . .
