"Installed" fonts not showing up in Windows Fonts folder
2018-07-23T12:31:42+00:00
Hi guys,
Unfortunately, none of the previous answers solves my problem.
I try to install fonts. According to Windows that also works but I cannot see the installed fonts in the Windows Fonts folder and neither do they show up in Illustrator.
When I copy a font file into the Windows Fonts folder it says "The "xxxxxx" font is already installed. Do you want to replace it?" - I click yes, but still - the font does not show.
It's not a problem of the font file as it was working previously. Same happens to hundreds of other fonts. Says they are installed but they don't show and they are not selectable in other applications.
Thanks for your help!
    2018-07-23T18:10:21+00:00
    As you can see my suggestion actually works for Windows 10 (and all other versions)
    2018-07-24T11:02:10+00:00
    Thanks Janey for your trying.
    Of course, I know how to install a font :)
    But my problem is this as follows:
    Before:
    Then I select a font and copy try to copy it in this folder. This happens:
    As you can see above, this font was not there. Anyway, I click yes, but it's still not there as you can see:
    2018-07-24T12:14:46+00:00
    Perhaps it is listed under another name?  Look under "London" in your list instead of "Chalet".
    2018-07-24T12:22:51+00:00
    Nope. This is also not the only font. I copied several hundred and in the fonts folder, there are only 231 listed.
    2018-07-24T16:24:37+00:00
    OK. Well, sorry I couldn't help. Hopefully someone else here can.
