file explorer not showing thumbnails for onedrive folder
2018-05-21T19:58:48+00:00
Many of my images have no thumbnail in my users one drive folder, even for files that are downloaded to my pc.
Full path C:\Users\myuser\OneDrive\Pictures\Camera Roll
How can I fix this? There was a time when thumbnails always worked for this folder, but I can't remember when this stopped working, it's been a couple/few weeks perhaps.
Also, why are some of the images near the end only available online. In my one drive settings this entire folder is set to sync.
2018-07-13T10:17:06+00:00
I had the same issue and to fix it I went into the settings of the One Drive app and disabled (untick) the Files On Demand service then hit OK. Then after a restart of the PC all thumbnails within my One Drive folders had returned.
No I idea why this works but it did for me and hopefully will do for you also.
80 additional answers
  1. Vijay A. Verma 104.9K Reputation points Volunteer Moderator
    2018-05-23T20:36:29+00:00
    I would recommend that you perform a Windows 10 repair upgrade. Repair upgrade fixes all Windows errors and retains all files, applications and settings. (You will not lose any data while backup is a good idea) Below is a good guide to perform repair upgrade
    https://www.tenforums.com/tutorials/16397-repai...
    Disclaimer - This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
    2018-07-16T20:45:20+00:00
    This worked for me also. Thanks Giant!
    2018-07-30T17:28:11+00:00
    Thanks Giant.... worked like a dream when my wifes comp had the same problem.
    2018-08-01T12:16:52+00:00
    I was able to resolved this case
    Just turn off Files on demand
    1.)Select the white or blue OneDrive cloud icon in the Windows taskbar notification area.
    2.) Click the three dots or ellipsis and then click Settings
    3.)Go on Settings tab > Under Files on Demand > Untick Save space and download files as you use them
    The One drive will restart itselft
    https://support.office.com/en-us/article/learn-about-onedrive-files-on-demand-0e6860d3-d9f3-4971-b321-7092438fb38e?ui=en-US&rs=en-US&ad=US
