Surface Book 2 Task View Lag (and other high-resolution laptops included)
2018-04-08T15:54:29+00:00
Ever since I got my Surface Book 2 (15 inch), Windows UI performance was quite sluggish. Windows framerate drops noticeably when opening Task View even with only one or two windows open, and switching desktop also experiences stutter.
I tried to diagnose the issue myself, by installing latest drivers for UHD 620 graphics from both Microsoft and Intel. I tried reinstalling / uninstalling drivers for GTX 1060. None of these worked, and I have reinstalled Windows several times but nothing has changed.
However, one "solution" to this problem was to decrease the screen resolution to 1620*1080 @ 100% scaling, which mitigated the issue significantly. The usage of UHD 620 graphics is much lower (shown under graph labelled "3D") with lower resolution and animation became much smoother. Upon research I discovered that this issue is not specific to my device. Many other laptops with high resolution displays were experiencing the same problem.
Here are some links to thread discussing seemingly similar issue:
4k laptop lag in Windows 10 UI animations
Laggy animations and effects at 4K resolution (running Windows 10)
Windows 10 Animation lags
Lag with Surface book 2
Is it that the Integrated Graphics Card in these laptops are not powerful enough to drive such a high resolution display? If so, the solution is not to lower the resolution as I did - that is just a poor excuse. Even my MacBook Pro Retina from 2012 performs better on MacOS than my Surface Book 2 does on Windows.
OR it is very likely that Windows 10 optimization on high-resolution laptops is just poor. It is ridiculous that such a high-end laptop experiences lag within its native OS only with few windows open; if Apple can do well with their animation on MacOS, there is no reason for Microsoft not to be able to do it.
Please look into this issue and fix it, Microsoft.
    2019-01-15T11:10:22+00:00
    Sadly, it's not a fix for me.
    Tbh, the performances are great on my 27" 2440p screen. They are going down only with higher resolutions.
    2019-01-16T02:13:24+00:00
    My issue mostly related to MS Excel.  I found that it could be resolved by turning graphics acceleration OFF in the Excel options.
    2019-01-16T08:29:47+00:00
    You need to see the link I provided.
    I've included it once more:
    https://www.reddit.com/r/h1z1/comments/7ool7n/everybody\_complaining\_about\_stuttering\_low\_fps\_on/
    You're welcome, enjoy the snappy UI ;)
    2019-03-04T16:21:54+00:00
    The transparency effect is killing the performance. Turn it off and it will run well for most of the time. Still, if you are doing some graphics-intensive tasks like playing 4k video. The stutters will be back.
    2019-03-05T07:40:48+00:00
    But you shouldn't be doing that. If you buy a machine that costs around 3000€ you would expect that at least the UI runs smoothly, and not to turn stuff off to get it to run as it should.
    Some people reduce the resolution, that's even worse when you pay extra to have a nice high res screen. How can Apple make for super smooth transparent UI that works even on 5k screens with the same hardware Microsoft has available?
