I'm glad this thread exists because as a recent buyer of the SB2, I've been noticing lag in all sorts of places (minimizing/maximizing windows, closing out tabs in Chrome, etc.) and it's been driving me crazy that no one else has mentioned it. Do you guys think I should return the laptop since I'm still within the return window or stick with it?
Surface Book 2 Task View Lag (and other high-resolution laptops included)
Ever since I got my Surface Book 2 (15 inch), Windows UI performance was quite sluggish. Windows framerate drops noticeably when opening Task View even with only one or two windows open, and switching desktop also experiences stutter.
I tried to diagnose the issue myself, by installing latest drivers for UHD 620 graphics from both Microsoft and Intel. I tried reinstalling / uninstalling drivers for GTX 1060. None of these worked, and I have reinstalled Windows several times but nothing has changed.
However, one "solution" to this problem was to decrease the screen resolution to 1620*1080 @ 100% scaling, which mitigated the issue significantly. The usage of UHD 620 graphics is much lower (shown under graph labelled "3D") with lower resolution and animation became much smoother. Upon research I discovered that this issue is not specific to my device. Many other laptops with high resolution displays were experiencing the same problem.
Here are some links to thread discussing seemingly similar issue:
4k laptop lag in Windows 10 UI animations
Laggy animations and effects at 4K resolution (running Windows 10)
Is it that the Integrated Graphics Card in these laptops are not powerful enough to drive such a high resolution display? If so, the solution is not to lower the resolution as I did - that is just a poor excuse. Even my MacBook Pro Retina from 2012 performs better on MacOS than my Surface Book 2 does on Windows.
OR it is very likely that Windows 10 optimization on high-resolution laptops is just poor. It is ridiculous that such a high-end laptop experiences lag within its native OS only with few windows open; if Apple can do well with their animation on MacOS, there is no reason for Microsoft not to be able to do it.
Please look into this issue and fix it, Microsoft.
2018-06-10T15:03:33+00:00 -
2018-06-10T15:54:27+00:00 If I knew that this issue was present before I purchased my SB2, I wouldn't have bought it. IMO this is unacceptable for a $3000 laptop, and if this is bugging you, return the laptop. Honestly the hardware is great, but the software experience is much more terrible than I had expected.
2018-06-10T15:59:23+00:00 I agree; when comparing it to a much inferior Windows 10 laptop at home, I notice how sluggish the SB is. I just hope that these problems are fixed so that I can purchase it again after I return it.
2018-06-29T12:19:23+00:00 did you find the solution?
sad ! my sruface book2 facing same problem !
2018-06-29T12:55:47+00:00 Sorry, but no....
What I would recommend you to do for now is to download "Custom Resolution Utility" and decrease your resolution to something like 2430×1620 @ 150% scaling. (If you can sacrifice resolution for smoothness, 1620×1080). Reducing the display resolution would mitigate the issue as I have mentioned above.
In fact, I ended up selling SB2 and getting a MacBook Pro, which is a shame because I loved the hardware of SB2. But in the end, the software experience in general has let me down.
Hopefully Microsoft will improve their software quality when they fully switch to UWP, but I won't count on them for now :(
