win version 1803 graphic driver not work proper. kindly update as soon as possible.
Display brightness at max after 1803 update
Hello!
I upgraded my laptop over the weekend to Windows 10 1803. I noticed my display was set to max brightness. I am unable to use the F keys to lower the brightness. I am also unable to change the brightness in the display settings. My drivers are all updated. Any suggestions on how to fix this?
I have a Toshiba Satellite with the Intel (R) HD Graphics.
2018-05-10T14:56:49+00:00 -
2018-05-11T11:36:23+00:00 i have the same problem on lenovo G460, with core i3 M370..... looking forward for solution
2018-05-11T12:26:17+00:00 I Have de same problem
win version 1803 graphic driver not work proper - Toshiba Tecra m11 - I5 520M.
2018-05-18T01:19:25+00:00 Lenovo G460 have same problem updated to 1803. Please follow up for this problem.
2018-05-23T21:28:37+00:00 THIS IS WHAT FIXED THE ISSUE FOR ME (Date: 23rd May 2018):
- I opened Device Manager.
- Noticed that Display Adapters section was reporting problem (showing exclamation sign) for the "Intel HD Graphics 620". (This solution may work for other onboard graphics too).
- I right clicked on that and chose "Update driver" option.
- On the pop-up window, I chose "Search automatically for updated driver software" option.
- Windows searched and automatically installed the driver software over Internet and the Brightness Controls started working again immediately (without restarting the PC).
- Device Manager also stopped reporting problem with Display Adapter.
I hope this helps some of you if not all of you.
