intel wireless-ac 9260 blue screen crash when installing adapter
2018-06-04T18:03:04+00:00
installing intel Bluetooth drivers works fine, and this part of the 9260 actually works. but whenever the wireless adapter is recognized and initialized I receive a blue screen crash with code BUGCODE_NDIS_DRIVER. upon restart, the adapter has a "!" in the icon next to its name, and within properties the device status reads either code 56 or code 37, depending on the latest attempt I have made to uninstall the adapter and drivers and reinstall the intel proset wireless drivers. I've tried all of intel proset's supported versions for this wifi adapter, but every driver version results in a blue screen of death upon initialization of the adapter. again, Bluetooth still works, and that's why i'm very confused. why is half of the 9260 working while the other half, the wifi part, is not? is there any fix or workaround for this? thanks.
    2018-06-04T19:00:20+00:00
    Where are you seeing windows 10 1803? I only see my version is 10.0.17134 build 17134.
    2018-06-04T18:54:40+00:00
    There seems to be some early adopter issues at this time with Windows 10 1803, if you can, I recommend you downgrade to your previous version until the Spring Creators Update matures with future cumulative updates.
    Press Control + Alt + Delete
    Click Sign out
    At the Sign In screen, hold down the shift key on your keyboard while clicking the Power button on the screen
    Continue to hold down the shift key while clicking Restart
    Continue to hold down the shift key until the Advanced Recovery Options menu appears
    Click Troubleshoot
    Click Advanced options
    Click Go back to the previous version of Windows
    Windows Update might attempt to upgrade to Windows 10 1803 again. See instructions how to block it:
    https://www.groovypost.com/howto/block-windows-...
    Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
    2018-06-04T18:51:43+00:00
    I already tried updating my motherboard's bios to the latest bios version, but that did not solve the issue. this would be bios 1.3 on the x299 extreme4 motherboard from asrock.
    chipset drivers are up to date.
    it is strange that the wireless part of this card is not working, but the integrated Bluetooth part of it IS working.
    I also just did another fresh install of windows 10, using the windows media creation tool from Microsoft, and attempted to manually install the intel drivers only (without proset software). The system crashed with the same BUGCODE_NDIS_DRIVER error code, and device status reads "windows is still setting up the class configuration for this device. (Code 56)." system restarts did not change the device status and wireless functionality is still absent.
    The exact make and model of the system? It is my own make, so system manufacturer, model and SKU fields show "to be filled by O.E.M."
    From system information:
    OS Name Microsoft Windows 10 Pro
    Version 10.0.17134 Build 17134
    Other OS Description  Not Available
    OS Manufacturer Microsoft Corporation
    System Name [Redacted]
    System Manufacturer To Be Filled By O.E.M.
    System Model To Be Filled By O.E.M.
    System Type x64-based PC
    System SKU To Be Filled By O.E.M.
    Processor Intel(R) Core(TM) i9-7960X CPU @ 2.80GHz, 2801 Mhz, 16 Core(s), 32 Logical Processor(s)
    BIOS Version/Date American Megatrends Inc. P1.00, 10/2/2017
    SMBIOS Version 3.0
    Embedded Controller Version 255.255
    BIOS Mode Legacy
    BaseBoard Manufacturer ASRock
    BaseBoard Model Not Available
    BaseBoard Name Base Board
    Platform Role Desktop
    Secure Boot State Unsupported
    PCR7 Configuration Binding Not Possible
    Windows Directory C:\Windows
    System Directory C:\Windows\system32
    Boot Device \Device\HarddiskVolume1
    Locale United States
    Hardware Abstraction Layer Version = "10.0.17134.1"
    User Name [redacted]
    Time Zone Pacific Daylight Time
    Installed Physical Memory (RAM) 64.0 GB
    Total Physical Memory 63.7 GB
    Available Physical Memory 59.2 GB
    Total Virtual Memory 73.2 GB
    Available Virtual Memory 68.4 GB
    Page File Space 9.50 GB
    Page File C:\pagefile.sys
    Kernel DMA Protection Off
    Virtualization-based security Not enabled
    Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not InstantGo, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
    Hyper-V - VM Monitor Mode Extensions Yes
    Hyper-V - Second Level Address Translation Extensions Yes
    Hyper-V - Virtualization Enabled in Firmware Yes
    Hyper-V - Data Execution Protection Yes
    The motherboard is ASRock x299 Extreme 4, processor is core i9 7960x, ram is 4x16gb g.skill tridentz dims, hard drive is Samsung 970 pro nvme 1tb. the motherboard has 1 m.2 socket (key e) supports type 2230 wifi/bt module, and the intel wireless-ac 9260ngw is type 2230 and supports key a or e socket for attaching the module. again, it is installed and the Bluetooth functionality works, it is just the wireless driver i'm having issues with.
    2018-06-04T18:13:12+00:00
    What is the exact make and model?
    Open Start, type: system information
    Hit Enter
    Click System summary
    Look in the right pane
    Copy the system sku info into reply here.
    See example: https://imgur.com/qzektpA
    Which version of Windows 10 is currently installed? See how to verify:
    https://answers.microsoft.com/en-us/windows/wik...
    Which version and edition Windows did you originally upgrade from or was installed prior to your current version:
    Windows 10 - 1703, 1607, 1511, 1507 (build 10240)
    Windows 7 Starter, Home Basic, Home Premium, Windows 8.0 Core, Windows 8.1 Windows 7 Professional, Windows 7 Ultimate, Windows 8.0 Pro, Windows 8.1 Pro
    It could mean you need to update your BIOS and Chipset drivers.
