Pc's all see one another and can share files, but some apps will not print over the network, Win 10 Photos and Adobe Reader.
Both these apps show connecting to the correct printer, but nothing prints.
Here is short description how I get my network sharing work with Windows 10 v1803.
(I haven't never use Homegroup so I start directly from step 2.)
Disconnect from non-existing Homegroup if you have used it.
2.1. All PC's: Check Network profile and Network discovery and Share settings
Sometimes this selection to change between Private and Public network profile is missing from Settings / Networks page. In that case profile must change by PowerShell. Right Click Windows Icon (Start button) and open PowerShell (Admin) and use following commands to get interface index number and change profile to Private (or Public):
Get-NetConnectionProfile
Set-NetConnectionProfile -InterfaceIndex <index number> -NetworkCategory Private
2.2. All PC's: Check Network Discovery and Share settings
Push Win Key and type "Services", locate these services.
- Function Discovery Provider Host
- Function Discovery Resource Publication
- SSDP Discovery
4.1. Check your current shares.
Open file explorer and type \localhost to address bar to see what shares are made in this computer.
4.2. Create new share (here I use folder "Test").
(Setting "Turn on sharing so anyone …" in Step 2.2. make share for folders in C:\Users automatic.)
Folder is now shared and Network share path is: \PCNAME\Test
4.3. Safe way to share folders.
Create user account to all users on your network to whom you want to give access to shared resources.
Use same user ID and password which they have on their own computers.
Right click "Test" and open Properties and select Security tab to see current settings.
Default security settings are shown in next picture.
Those settings allow access to shared folder(s) only for those users who have user ID on that computer.
4.4. Sharing folder "Test" to Everyone" (Very unsafe setting! Think carefully do you need to select this!)
If you want that everyone have access to that share then go to Security tab and:
Now anyone on your home network should have access to shared folders without credentials or having user account on your computer.
This should be cover the essentials to sharing your data over local network. This share is not limited to C:\Users folder, every folder can be handled like shown in steps 4.
Now your PC's should visible, but if not then try to reset all network settings:
Go to Settings / Network & Internet / Status, scroll down to find "Network reset, on next window click "Reset Now" button.
It will takes about 5 min to perform this reset and then PC reboot automatic.
When you sing in first time you get notification something like "Do you want your PC to be access by other computers", click Yes for that.
If you get error message "Windows cannot access \PC_NAME" when you try to connect shared folders then continue to step 6.
If you get error "\PCNAME path not found" you can solve this by adding your PC's and IP-addresses to hosts file.
6.1 New routers (or modems) may have feature to remember which IP-addresses are assign to each device, but with older routers (or modems) you have to check that your router or modem is set give predefined IP-addresses linked to each PC's MAC-address.
This way PC's will get same IP-address every time when it ask IP-address form router (or modem) DHCP-server.
There should be some kind of list of PC names with MAC addresses and given IP-addresses of each connected PC.
Picture show that list on my router. In my case with old router I had to select manual assignment in each line.
6.2. Add all PC's IP-addresses and Names to hosts file (C:\Windows\System32\drivers\etc\hosts).
You can check your IP-address and PC's name by opening command prompt (CMD)
For IP-address type command: ipconfig you get line like this: IPv4 Address ………. 192.168.100.101
For PC name type command: hostname
Write down IP-address and Name of each PC and add those to that hosts file.
To edit copy hosts file to some another location, right click it and use notepad to edit and save it. Replace original file with edited file. Because hosts file is located on system folder replace will ask administrators rights to perform it.
# 127.0.0.1 localhost
# ::1 localhost
192.168.100.101 PC1 # Ethernet
192.168.100.102 PC2 # Ethernet
192.168.100.202 PC2 # Wi-Fi
6.2. Add all PC's IP-addresses and Names to C:\Windows\System32\drivers\etc\hosts file.
Take down IP-address and Names of each PC and add those to that hosts file.
localhost name resolution is handled within DNS itself.
# ::1 localhost
My networking issues started after plugging in a new router nearly 2 weeks ago which has meant that one of our team has been unable to function properly since then.
I have tried absolutely everything from numerous forums, but the thing that worked to resolve the issue was step 6.2 of this guide - this is the first post I have seen with this advice
Thank you so much for posting this!
Nice to see that you find this and get helped.
This is nothing new, been happening way before 1803. I have for four years created the same posts about the same networking issues that everyone is claiming is a new thing which it is not. So what if I did all that and even more and it still does not work?
For me i open network, click the computers and it says can't be found but if I click it over and over and over and over, it will eventually work
I can be in a share, go forward one window, then click back, the PC can not be found, go forward, it is there, go back it is not, go forward it is there go back once more it works.
On a windows desktop typing the IP addresses helps and works tremendously put go to a non computer and through SMB or NFS try to access that same IP, it will not work.
Maybe if windows actually cared they would fix this but they are to busy making programs for us so we can make 3d cats and they are more focus on creating a time line to violate your privacy. It will never get fixed. because fixing it means efficiency and we can't have that now can we?
