Lumia 950XL - Project My Screen not working after Win10 1803 Update - Black Screen
2018-05-17T12:08:56+00:00
I use my 950XL extensively for demos of my company's software because it's much better display than my iPhone and doesn't need additional apps to do it.
I updated my Win10 desktop today to 1803 and also my phone updated to .104 and the app no longer works.
When I open the app I get the message on the phone to ask if I want to share and I agree. The display on the desktop is black, but I can actually start applications on the phone by clicking inside the black window, so there obviously is a connection, just no display.
I was working perfectly, but not now.
As a workaround, is it possible to use continuum? I'm sure there used to be an option to display the phone's screen rather than a full desktop to the connected display but that appears to be no longer available
Chris
***Moved from: Mobile Devices / Microsoft Lumia and Nokia Lumia / Continuum / 900-series.***
Windows for home | Windows 10 | PC projection
    2019-01-04T00:39:37+00:00
    Hummm...  I can download it from the following links as long as I login with Microsoft account.
    Has anyone been able to download it?
    Does anyone have same issue?
    https://onedrive.live.com/?id=2B7D4C9124F458C3%21562265&cid=2B7D4C9124F458C3
    https://1drv.ms/f/s!AsNY9CSRTH0roqhZlAT6e9xFN8KmHg
    2019-01-04T03:41:00+00:00
    I was able to download the file from the above links.  I was logged in to my Microsoft account.  That may make a difference.
    2019-01-04T07:55:23+00:00
    amazing. downloaded it, installed and it simply works. Thank you so much, I missed this Programm with my mobile device.
    Never tought it would work again, but with People with computer knowlegde it is possible. All the best for 2019.
    2019-01-04T11:29:34+00:00
    Not only it works !. It works much better than the original one.. and with more functions.
    Once more, many thanks to nyama3310 who did a great job.
    Have a prosperous 2019, all of you !!.
    2019-01-06T12:50:29+00:00
    Sorry, may be there was a problem with my browser. I was able to download it with the using a different browser.
