260ci WIA Driver USB problem
2018-04-18T16:58:51+00:00
What is this?  Under device manager, Imaging Devices,  shows orange exclamation mark; tried to update but here is information under Properties:
This device cannot start. (Code 10)
The specified request is not a valid operation for the target device.
Device ROOT\IMAGE\0001 was deleted.
Class Guid: {6BDD1FC6-810F-11D0-BEC7-08002BE2092F}
I also tried troubleshooting under Hardware & Devices but problem is unresolved. Can I uninstall this?
DaveM121 936.3K Reputation points Independent Advisor
2018-04-18T18:11:29+00:00
Hi Winnie5560,
In Device Manager, right click that device and choose 'Disable' - don't uninstall it as Windows will just re-install it.
That should stop the popups you are getting !!
40 additional answers
    2018-11-15T10:39:21+00:00
    usb\vid_0482&pid_061d&mi_01
    2018-11-23T13:11:50+00:00
    2018-12-31T02:22:27+00:00
    2019-01-09T12:21:30+00:00
    260ci WIA Driver (USB)
