Hi Winnie5560,
In Device Manager, right click that device and choose 'Disable' - don't uninstall it as Windows will just re-install it.
That should stop the popups you are getting !!
What is this? Under device manager, Imaging Devices, shows orange exclamation mark; tried to update but here is information under Properties:
This device cannot start. (Code 10)
The specified request is not a valid operation for the target device.
Device ROOT\IMAGE\0001 was deleted.
Class Guid: {6BDD1FC6-810F-11D0-BEC7-08002BE2092F}
I also tried troubleshooting under Hardware & Devices but problem is unresolved. Can I uninstall this?
Hi Winnie5560,
Hi!! I am having this exact same issue and followed your instructions, can you help me?
Hi LexiLopez1,
I am not very computer technical but can give you basic instructions:
Go to Device Manager (control panel)
Find Imaging devices and click on sub folder: Kyocera
Right click and disable
I am not certain why this driver exists as I never had a Kyocera printer/scanner.
Hope this works for you.
Hello Joaodos Santon Lima,
Please read the post reply dated April 18 2018 for the fix on this issue.
I have no further information on this issue but the suggestion seemed to work.
Thanks!
