FORTNITE-dx11 feature level 10.0 is required to run the engine
2018-06-16T15:55:53+00:00
2018-06-16T23:39:40+00:00
Hi Bigherb72204_72114,
The error message "DX11 feature level 10.0 is requires to run the engine" occurs when your computer doesn’t have the required hardware feature Another factor why you see this error is the graphics card driver issue, so you should make sure that your graphics card driver is working properly. I personally found a related thread which you may find helpful on your end. Here's the link. furthermore, kindly follow these steps to help you resolve your concern:
Method 1: Install the latest patch for your gaming app. The game developers keep releasing patches to improve the games and fix issues.
Method 2: Update your graphics card driver. You may refer to this link. You can also manually download the driver from the manufacturer’s website, and install it in your computer to update the graphics card driver.
Method 3: Check the latest version of DirectX. Here's how:
  1. From Start, type dxdiag in the Search box, and then press enter.
  2. Tap or click on dxdiag from the results.
  3. Check DirectX Version on the first page of the report in the System Information section.
You may also refer to this link.
Note: DirectX 11.3 and 12 are included with these Windows versions. Updates will be available through Windows Update. There is no stand-alone package for these versions of DirectX.
If the issue persists, please contact the game developer for better assistance.
Do let us know if you have any other concerns.
72 additional answers
    2019-12-09T01:38:53+00:00
    I have Direct X11 with 10.1 and fortnite is still not working!! Help me plz!
    2019-12-29T23:20:44+00:00
    I have DX12 so i dont know if it should work or not. because i keep getting the same messsage.
    2020-01-16T18:21:26+00:00
    i tried it and it never worked
    2020-01-18T17:57:57+00:00
    can I pls get it I need it so I can play fortnite
