I upgraded to 1803 and have only found one issue (so far) that needs addressing. When I go to Settings-Apps-Default Apps and choose the link to "Set defaults by app" at the bottom, the page just closes (disappears). It acts like it is trying to load the page but just ends up closing. I have tried running SFC and DISM and even repairing/resetting Edge all to no avail.
Some devices may hang or freeze when using certain apps, such as “Hey Cortana” or Chrome, after installing the Windows 10 April 2018 Update
Microsoft is aware that some devices running the Windows 10 April 2018 Update (version 1803) may hang or freeze when using certain apps, such as “Hey Cortana” or Chrome.
If your device freezes when using an app, try one of the following steps to recover Windows without needing to restart:
- Try a Windows key sequence to wake the screen. If you have a keyboard connected, simultaneously press the Windows logo key + Ctrl + Shift + B. If you’re on a tablet, simultaneously press both the volume-up and volume-down buttons, three times within 2 seconds. If Windows is responsive, a short beep will sound and the screen will blink or dim while Windows attempts to refresh the screen.
- If you’re using a laptop, close and open the laptop lid.
Microsoft is working on a solution with the goal of including it in the next regular monthly update, currently targeted for a release date of May 8, 2018.
Update (5/8/18): A solution was included in the May 8th, 2018 cumulative update (KB4103721). Windows Update will automatically download and install the solution. To check for updates now, select the Start button, and then go to Settings > Update & security > Windows Update, and select Check for updates. If your system still experiences performance problems after installing the latest updates, you may be experiencing a different issue. Please describe your issue in another thread or by using the Feedback Hub.
Windows for home | Windows 10 | Cortana and search
2018-05-07T19:21:40+00:00 -
2018-05-08T00:39:38+00:00 Experienced quite a few freezes after latest update, my system used to be quite fast and responsive before. Only option was to hard reset which is so dangerous and annoying... Please solve the issues on May 8th...
2018-05-08T07:30:34+00:00 my pc is getting that windows hello isn't available on this pc the what I should do
2018-05-08T09:19:31+00:00 I am still waiting for the update, Microsoft! regular, unexplained freezes on the April build (installed before May 8)
2018-05-08T14:17:43+00:00 KB4135051 fixes the freezing on 4 laptops in our office so far today......
