I've recovered Windows 10 back to version 1709 on my tablet and it is running very well. I've set my wifi to metered to stop windows update from downloading version 1803.
As expected, M$ is s***
Microsoft is aware that some devices running the Windows 10 April 2018 Update (version 1803) may hang or freeze when using certain apps, such as “Hey Cortana” or Chrome.
If your device freezes when using an app, try one of the following steps to recover Windows without needing to restart:
Microsoft is working on a solution with the goal of including it in the next regular monthly update, currently targeted for a release date of May 8, 2018.
Update (5/8/18): A solution was included in the May 8th, 2018 cumulative update (KB4103721). Windows Update will automatically download and install the solution. To check for updates now, select the Start button, and then go to Settings > Update & security > Windows Update, and select Check for updates. If your system still experiences performance problems after installing the latest updates, you may be experiencing a different issue. Please describe your issue in another thread or by using the Feedback Hub.
There are a number of ways by which you can get rid of freezing issues like:
Detailed steps can be found in the article given below:
How to permanently fix Windows 10 Freezing Issue
It actually worked very well for me. Hope it helps you too.
Cheers.
update all windows install
My PC was crashing/freezing in 1709 version too (and now in 1803). 1703 was working fine. Windows 10 actually is a crap (only problems and issues) and I think it is time to switch to the Mac.
