My PC will not accept my opening when using my 4 digit pin. It just shows a static I and will not react to any key actions. I then have to do a restart. It then reacts as normal and lets me enter with my pin. A real timewaster and a nuisance. Can anyone advise please?
Some devices may hang or freeze when using certain apps, such as “Hey Cortana” or Chrome, after installing the Windows 10 April 2018 Update
Microsoft is aware that some devices running the Windows 10 April 2018 Update (version 1803) may hang or freeze when using certain apps, such as “Hey Cortana” or Chrome.
If your device freezes when using an app, try one of the following steps to recover Windows without needing to restart:
- Try a Windows key sequence to wake the screen. If you have a keyboard connected, simultaneously press the Windows logo key + Ctrl + Shift + B. If you’re on a tablet, simultaneously press both the volume-up and volume-down buttons, three times within 2 seconds. If Windows is responsive, a short beep will sound and the screen will blink or dim while Windows attempts to refresh the screen.
- If you’re using a laptop, close and open the laptop lid.
Microsoft is working on a solution with the goal of including it in the next regular monthly update, currently targeted for a release date of May 8, 2018.
Update (5/8/18): A solution was included in the May 8th, 2018 cumulative update (KB4103721). Windows Update will automatically download and install the solution. To check for updates now, select the Start button, and then go to Settings > Update & security > Windows Update, and select Check for updates. If your system still experiences performance problems after installing the latest updates, you may be experiencing a different issue. Please describe your issue in another thread or by using the Feedback Hub.
Windows for home | Windows 10 | Cortana and search
2018-05-19T14:04:09+00:00 -
2018-05-19T23:48:52+00:00 After updating, my PC hangs and looks like this with several attenpt of hard restart ...
Damn MS, stop trying new **** ‘cause we’re happy the way things are!!
If it ain’t broken, stop trying to “fix” things because youre making things worse!!
You’re aways asking how’s customer experience ... well it sucks since Windows 7 & 9!!
2018-05-20T03:00:00+00:00 Mine will not go anyway I try i am at c promp on my PC trying to figure out how to make changes to fix it.
2018-05-20T03:02:03+00:00 That is mine on the bottom
2018-05-20T03:04:40+00:00 Mine will not go anyway I try i am at c promp on my PC trying to figure out how to make changes to fix it.
By some miraculous works (maybe I had hard restart my PC several times??) my PC went into automatic restoration to the earlier Windows version (before the updated ****) and it's working well again ...
I'm only a simple IT user so I can't explain how, but if you can try to get the PC to restore the previous version should be fine I think ...
