It's nearly a month later and I never received the supposed solution.
Checking for updates today, I find KB4100403 instead. ??
Microsoft is aware that some devices running the Windows 10 April 2018 Update (version 1803) may hang or freeze when using certain apps, such as “Hey Cortana” or Chrome.
If your device freezes when using an app, try one of the following steps to recover Windows without needing to restart:
Microsoft is working on a solution with the goal of including it in the next regular monthly update, currently targeted for a release date of May 8, 2018.
Update (5/8/18): A solution was included in the May 8th, 2018 cumulative update (KB4103721). Windows Update will automatically download and install the solution. To check for updates now, select the Start button, and then go to Settings > Update & security > Windows Update, and select Check for updates. If your system still experiences performance problems after installing the latest updates, you may be experiencing a different issue. Please describe your issue in another thread or by using the Feedback Hub.
I have noticed that I am having the same issue. I tried the Windows logo key + Ctrl + Shift + B, and it made the frozen mouse cursor disappear, but did not unfreeze the computer. I have went and look at my Windows 10 Pro version number and it is showing 1709, OS Build 16299.371. So my question is, is anybody having this issue with freezing using 1709 version also. I definitely have it freeze mostly using Google Chrome and rarely with other apps and programs. I have checked Task Manger and verified, I am not pegging 100% on CPU, memory, or disk.
Never on 1709, that I can recall. Except for frequently frozen mouse pointer. That, to me, seems peculiar to a WiFi mouse. Not so much with USB mice I had in the past, except maybe if the sensor was dirty or something...
Chrome does use a lot of RAM, especially the way I often use it, with multiple tabs open and multiple add-ons/extensions. And, btw, the Windows logo key + Ctrl + Shift + B fix doesn't help that much with Chrome itself even tho RAM usage is running at about 50% total. Seems to have unfrozen most other apps running at the same time.
I was using a program which did use 100% available CPU, with no effect on performance.
Only since the "1803" update has there been constant app hangs and occasional screen freezes.
According to my System Information it's not 1803, but Version 10.0.17134 Build 17134. ??
So what should we do? Wait for an update?
Guess so as nobody else here has any bright ideas.
Hopefully this problem will be resolved this month. I only had started having the problem in late May.
I think we now need to pay attention to the OS build we are installing. I was finally able to install 1803 on my brand new ASUS only to roll it back after a few hours of blue screens. The build I installed was OS Build 17134.48. It seems there is a latter build May 23, 2018—KB4100403 (OS Build 17134.81) Note the .81 as opposed to the .48. I am not installing anything (if I have a choice) until I read that there is a stable release.
OS Build 17134.81 is the build I have installed, there is no updates since.
I can also confirm, that the latest Insider Preview release has the same issue I am having.
