Media Player web address for album info changed in recent Windows 10 upgrade
2018-05-06T16:38:03+00:00
After a recent major upgrade for Windows 10, my Windows Media Player is trying to find Album information from a new website that does not work.  The old web address was (fai.music.metaservices.microsoft.com) and new web address it is using is (musicmatch-ssl.xboxlive.com) which is not a valid address.  How do I change the web address used for album metadata back to correct address?  Searched old message boards with no luck.
2018-07-07T13:27:41+00:00
Found a solution that worked for me:
  1. Start regedit.exe
  2. Navigate to "Computer\HKEY_CURRENT_USER\Software\Microsoft\MediaPlayer\TunerConfig"
  3. Look for setting PREFERREDMETADATAPROVIDER -- it should have a value "pmpMusicMatch"
  4. Edit the setting PREFERREDMETADATAPROVIDER, and clear the value so you have a blank value
  5. Save / exit regedit.exe
  6. Restart Windows Media Player, you should be restored back to fai.music.metaservices.microsoft.com
What an unnecessary pain in the proverbial.
Update: this DOES NOT WORK any more.
Microsoft appear to have strangled this option off entirely. We are now stuck with the much lesser offering that is "musicmatch-ssl.xboxlive.com".
Microsoft: thanks for nothing.
158 additional answers
    2018-07-09T07:05:55+00:00
    Thanks Tom Austin.
    Your registry change worked for me....spent at least a good hour looking for solution.
    Wallah!
    FFS Mr. Softee !
    Ed
    2018-07-09T07:13:25+00:00
    Great, and I just reverted back to previous update and disabled the latest one. I will redo the update and try that solution then.
    2018-07-16T09:44:03+00:00
    Thanks Tom Austin for your simple and efficient solution!
    A relevant option is that Microsoft simply wants to promote their a bit forgotten Groove player (and it's paying streaming now..) and see the well-known and very much used, good working WMP as kind of bothersome now, so they put that bug; looks all like a small marketeering plot, but maybe this is wrong possibly. Remember anyway, they wanted all 'new things' for Windows 10, right from the start of the launching of it.
    2018-07-26T15:21:41+00:00
    Thanks Tom: very much appreciated.
