Media Player web address for album info changed in recent Windows 10 upgrade
2018-05-06T16:38:03+00:00
After a recent major upgrade for Windows 10, my Windows Media Player is trying to find Album information from a new website that does not work.  The old web address was (fai.music.metaservices.microsoft.com) and new web address it is using is (musicmatch-ssl.xboxlive.com) which is not a valid address.  How do I change the web address used for album metadata back to correct address?  Searched old message boards with no luck.
2018-07-07T13:27:41+00:00
Found a solution that worked for me:
  1. Start regedit.exe
  2. Navigate to "Computer\HKEY_CURRENT_USER\Software\Microsoft\MediaPlayer\TunerConfig"
  3. Look for setting PREFERREDMETADATAPROVIDER -- it should have a value "pmpMusicMatch"
  4. Edit the setting PREFERREDMETADATAPROVIDER, and clear the value so you have a blank value
  5. Save / exit regedit.exe
  6. Restart Windows Media Player, you should be restored back to fai.music.metaservices.microsoft.com
What an unnecessary pain in the proverbial.
Update: this DOES NOT WORK any more.
Microsoft appear to have strangled this option off entirely. We are now stuck with the much lesser offering that is "musicmatch-ssl.xboxlive.com".
Microsoft: thanks for nothing.
158 additional answers
    2019-10-04T20:47:11+00:00
    Did a search for "Computer\HKEY_CURRENT_USER\Software\Microsoft\MediaPlayer\TunerConfig".
    Not in the registry.
    I did a search for just, "TunerConfig", in my registry.
    It doesn't exist.
    So the fix doesn't work for me.
    That's too bad. Thought finally someone who has the answer.
    2019-10-08T02:43:52+00:00
    Is there a solution for Windows 8.1 to get album Info to work?
    There is no TunerConfig entry in the registry
    2019-10-08T13:01:10+00:00
    i also cannot update album info on my wmp. am using win7
    2019-10-08T13:03:54+00:00
    i cannot find Tuner Config,can only find Media Play.er
