Media Player web address for album info changed in recent Windows 10 upgrade
2018-05-06T16:38:03+00:00
After a recent major upgrade for Windows 10, my Windows Media Player is trying to find Album information from a new website that does not work.  The old web address was (fai.music.metaservices.microsoft.com) and new web address it is using is (musicmatch-ssl.xboxlive.com) which is not a valid address.  How do I change the web address used for album metadata back to correct address?  Searched old message boards with no luck.
2018-07-07T13:27:41+00:00
Found a solution that worked for me:
  1. Start regedit.exe
  2. Navigate to "Computer\HKEY_CURRENT_USER\Software\Microsoft\MediaPlayer\TunerConfig"
  3. Look for setting PREFERREDMETADATAPROVIDER -- it should have a value "pmpMusicMatch"
  4. Edit the setting PREFERREDMETADATAPROVIDER, and clear the value so you have a blank value
  5. Save / exit regedit.exe
  6. Restart Windows Media Player, you should be restored back to fai.music.metaservices.microsoft.com
What an unnecessary pain in the proverbial.
Update: this DOES NOT WORK any more.
Microsoft appear to have strangled this option off entirely. We are now stuck with the much lesser offering that is "musicmatch-ssl.xboxlive.com".
Microsoft: thanks for nothing.
158 additional answers
    2019-09-09T21:31:00+00:00
    Perhaps we can think of other strategies in order to persuade Microsoft to listen to our concerns regarding their business decision to stop support of their perfectly fine media player. Is there anothe email address or phone number we could use to blast out this message?
    2019-09-09T23:10:55+00:00
    I've moved on....3 strikes and microsoft is O U T !!!!!
    Nero and Gracenote is my solution.
    2019-09-30T11:43:41+00:00
    Thanks a bunch for the fix.  Its lame how uSoft have not fixed it
    2019-09-30T22:09:17+00:00
    None of these entries appear in my registry.
    I did separate searches for :
    TunerConfig
    pmpMusicMatch
    I did find "Computer\HKEY_CURRENT_USER\Software\Microsoft\MediaPlayer", but it didn't have the subfolder "TunerConfig".
    So I'm still at step one, with broken software.
