Media Player web address for album info changed in recent Windows 10 upgrade
2018-05-06T16:38:03+00:00
After a recent major upgrade for Windows 10, my Windows Media Player is trying to find Album information from a new website that does not work.  The old web address was (fai.music.metaservices.microsoft.com) and new web address it is using is (musicmatch-ssl.xboxlive.com) which is not a valid address.  How do I change the web address used for album metadata back to correct address?  Searched old message boards with no luck.
2018-07-07T13:27:41+00:00
Found a solution that worked for me:
  1. Start regedit.exe
  2. Navigate to "Computer\HKEY_CURRENT_USER\Software\Microsoft\MediaPlayer\TunerConfig"
  3. Look for setting PREFERREDMETADATAPROVIDER -- it should have a value "pmpMusicMatch"
  4. Edit the setting PREFERREDMETADATAPROVIDER, and clear the value so you have a blank value
  5. Save / exit regedit.exe
  6. Restart Windows Media Player, you should be restored back to fai.music.metaservices.microsoft.com
What an unnecessary pain in the proverbial.
Update: this DOES NOT WORK any more.
Microsoft appear to have strangled this option off entirely. We are now stuck with the much lesser offering that is "musicmatch-ssl.xboxlive.com".
Microsoft: thanks for nothing.
158 additional answers
    2019-06-15T18:50:48+00:00
    since your last update nothing on windows media works the way it was no fai works cant download songs you screwed it up how about fixing the problem that you created
    2019-06-15T20:47:29+00:00
    The only software for ripping should be EAC.
    As for media player and metadata updater, whatever suits you. I'll look into the Media Monkey.
    2019-06-15T21:01:32+00:00
    microsoft sucks for killing this off....pitful.
    2019-06-16T11:31:34+00:00
    I'm inclined to agree with Tony on this, Microsoft are crippling WMP with removing the fai metaservice.
    For those that can cope with losing the superior fai metaservice library and reverting back to the inferior XBox library in WMP, the steps are simpy this:
    4. Edit the setting PREFERREDMETADATAPROVIDER, and set the value to "pmpMusicMatch"
    6. Restart Windows Media Player, you should be restored back to the XBox library
    It's not as good, but at least it works.
