File Explorer may not detect other devices or perform file sharing on the local network when running Windows 10 version 1803
2018-06-22T02:04:41+00:00
After installing the Windows 10 April 2018 Update (Windows 10 version 1803), File Explorer cannot connect to other devices running version 1803.  When clicking the Network tab in File Explorer, other devices on the home network running version 1803 do not appear, and thus I’m not able to perform file sharing or access files on other devices on my home network.
2018-06-22T02:12:16+00:00
Microsoft is aware of reports that devices running Windows 10 version 1803 cannot connect to other devices on their home network and is investigating the issue.
You can resolve this problem by setting some services to Automatic (Delayed Start) and restarting Windows:
  1. Press the Windows Key and R at the same time to bring up the Run dialog.
  2. Type services.msc in the Run dialog and press Enter.
  3. For each of the following services, locate the service in list, right-click the service and select Properties.  Then set the Startup type to Automatic (Delayed Start) and select Apply.
    • Computer Browser (Browser)
    • Function Discovery Provider Host (FDPHost)
    • Function Discovery Resource Publication (FDResPub)
    • Network Connections (NetMan)
    • UPnP Device Host (UPnPHost)
    • Peer Name Resolution Protocol (PNRPSvc)
    • Peer Networking Grouping (P2PSvc)
    • Peer Networking Identity Manager (P2PIMSvc)
  4. Restart Windows.
Should you have any other concerns don't hesitate to post back.
240 additional answers
  1. Deleted
  2. Deleted
    2018-08-05T21:42:51+00:00
    The above does not always work, what it appears to have happened is the update has reset all the file permissions on your machines so you can only access the files from that machine as its admin if you add group as everybody and give full control on all the drives you get networking back.
    This gave me my network of 7 desktops and two laptops back but I do not know if a further update from Microsoft will change stuff again, WHEN WILL MICROSOFT GET IT INTO ITS FAT HEADS THE MACHINES BELONG TO US NOT MICROSOFT!!!! IF THEY WANT TO MESS ABOUT WITH THEM BUY THEM FROM US AT MARKET VALUE!!!!
  4. Deleted
