File Explorer may not detect other devices or perform file sharing on the local network when running Windows 10 version 1803
2018-06-22T02:04:41+00:00
After installing the Windows 10 April 2018 Update (Windows 10 version 1803), File Explorer cannot connect to other devices running version 1803.  When clicking the Network tab in File Explorer, other devices on the home network running version 1803 do not appear, and thus I’m not able to perform file sharing or access files on other devices on my home network.
2018-06-22T02:12:16+00:00
Microsoft is aware of reports that devices running Windows 10 version 1803 cannot connect to other devices on their home network and is investigating the issue.
You can resolve this problem by setting some services to Automatic (Delayed Start) and restarting Windows:
  1. Press the Windows Key and R at the same time to bring up the Run dialog.
  2. Type services.msc in the Run dialog and press Enter.
  3. For each of the following services, locate the service in list, right-click the service and select Properties.  Then set the Startup type to Automatic (Delayed Start) and select Apply.
    • Computer Browser (Browser)
    • Function Discovery Provider Host (FDPHost)
    • Function Discovery Resource Publication (FDResPub)
    • Network Connections (NetMan)
    • UPnP Device Host (UPnPHost)
    • Peer Name Resolution Protocol (PNRPSvc)
    • Peer Networking Grouping (P2PSvc)
    • Peer Networking Identity Manager (P2PIMSvc)
  4. Restart Windows.
Should you have any other concerns don't hesitate to post back.
240 additional answers
    2018-08-01T15:11:51+00:00
    4. Restart Windows.
    I want your support
    2018-08-01T17:48:12+00:00
    4. Restart Windows.
    I want your support
    Shibualex1, I tried all the changes you suggested and it is still behaving the same way - it works randomly.
    2018-08-01T18:17:31+00:00
    {08/01/18 @ 14:17 EDT}
    Original Problem: Three PCs are connected on a LAN
    PCs 1 & 2 can see (device and files) each other but not PC3
    PC3 can see all three PCs.
    How can PCs 1 & 2 see PC3?
    Remaining Problem: PC2's access to PC3 files fades in and out. Seems to be a s/w conflict.
    Could check:
    • []Antivirus s/w
    • []Windows 10 Defender Firewall
    These settings are working for my Local Network configuration of three PCs on a LAN
    Windows Logo + R, Run: services.msc
    • Previously changed all three Peer Services to Automatic (Delayed Start)
    • Previously changed all two FD Services to Automatic or Automatic (Delayed Start)
    • Browser, NetMan, & UPnPHost remain set to Manual
    Other changes
    • Changed back to Password Protected Sharing
      • (Settings > Network & Sharing > Sharing Options > All Networks)
    • Restarted all three PCs
    • Restarted Netgear Router (LAN)
    2018-08-01T18:27:29+00:00
    {08/01/18 @ 14:27 EDT}
    Could check:
    • []Antivirus s/w
    Other changes
