File Explorer may not detect other devices or perform file sharing on the local network when running Windows 10 version 1803
2018-06-22T02:04:41+00:00
After installing the Windows 10 April 2018 Update (Windows 10 version 1803), File Explorer cannot connect to other devices running version 1803.  When clicking the Network tab in File Explorer, other devices on the home network running version 1803 do not appear, and thus I’m not able to perform file sharing or access files on other devices on my home network.
2018-06-22T02:12:16+00:00
Microsoft is aware of reports that devices running Windows 10 version 1803 cannot connect to other devices on their home network and is investigating the issue.
You can resolve this problem by setting some services to Automatic (Delayed Start) and restarting Windows:
  1. Press the Windows Key and R at the same time to bring up the Run dialog.
  2. Type services.msc in the Run dialog and press Enter.
  3. For each of the following services, locate the service in list, right-click the service and select Properties.  Then set the Startup type to Automatic (Delayed Start) and select Apply.
    • Computer Browser (Browser)
    • Function Discovery Provider Host (FDPHost)
    • Function Discovery Resource Publication (FDResPub)
    • Network Connections (NetMan)
    • UPnP Device Host (UPnPHost)
    • Peer Name Resolution Protocol (PNRPSvc)
    • Peer Networking Grouping (P2PSvc)
    • Peer Networking Identity Manager (P2PIMSvc)
  4. Restart Windows.
Should you have any other concerns don't hesitate to post back.
240 additional answers
    2018-07-25T14:52:48+00:00
    4. Restart Windows.
    Shou,ld you have any other concerns don't hesitate to post back.
     my laptop is window 8 but I  want window 10 so I request runout window 10
  2. Deleted
    2018-07-25T17:24:08+00:00
    4. Restart Windows.
    OK, even though most users reported this did not work I tried it with my two windows Pro laptops and my Windows Home unit.   As all said the first service "Computer Browser" generated an error when I tried to set it to Automatic (delayed start).   The rest took my change.   It does seem to work,  in a limited way at least.   I can see all 3 systems but I'm having trouble sharing from WIn Pro units to the Win Home unit.   Can't seem to get it to let me in.  I'll keep trying when I have nothing better to do.
    2018-07-25T17:33:40+00:00
    the fix does not work, I tried it on six different computers that did work before upgrade.
    I can ping all network computers with ip address. when I try to use name they just ****.
    can remote desktop all computers using ip address but not name.
    only see the logged in computer in use on the network.
    this is getting very time consuming and irritating. it used to work fine, Microsoft just revert back to before the fix/update then redo the update and make sure you don't crash the sharing function.
