File Explorer may not detect other devices or perform file sharing on the local network when running Windows 10 version 1803
2018-06-22T02:04:41+00:00
After installing the Windows 10 April 2018 Update (Windows 10 version 1803), File Explorer cannot connect to other devices running version 1803.  When clicking the Network tab in File Explorer, other devices on the home network running version 1803 do not appear, and thus I’m not able to perform file sharing or access files on other devices on my home network.
2018-06-22T02:12:16+00:00
Microsoft is aware of reports that devices running Windows 10 version 1803 cannot connect to other devices on their home network and is investigating the issue.
You can resolve this problem by setting some services to Automatic (Delayed Start) and restarting Windows:
  1. Press the Windows Key and R at the same time to bring up the Run dialog.
  2. Type services.msc in the Run dialog and press Enter.
  3. For each of the following services, locate the service in list, right-click the service and select Properties.  Then set the Startup type to Automatic (Delayed Start) and select Apply.
    • Computer Browser (Browser)
    • Function Discovery Provider Host (FDPHost)
    • Function Discovery Resource Publication (FDResPub)
    • Network Connections (NetMan)
    • UPnP Device Host (UPnPHost)
    • Peer Name Resolution Protocol (PNRPSvc)
    • Peer Networking Grouping (P2PSvc)
    • Peer Networking Identity Manager (P2PIMSvc)
  4. Restart Windows.
Should you have any other concerns don't hesitate to post back.
240 additional answers
    2018-07-18T07:15:36+00:00
    Many of us have that result.....there doesn't seem to be any kind of resolution to this problem.
    First time since MS was born I regret using their products.
    2018-07-18T07:46:30+00:00
    Computerbrowser is not neccessary, forget about this service and error! It doesn't matter!
    2018-07-18T08:38:48+00:00
    I had already tried to view files in spite of the Computer Browser error and all was well!
    2018-07-18T10:59:43+00:00
    I dont know if its fixed but I set Enable insecure guest logons and I can access my NAS Drive fine but if I turn it off I can't, I'm on the Enterprise edition of W10 And its 1803
