File Explorer may not detect other devices or perform file sharing on the local network when running Windows 10 version 1803
2018-06-22T02:04:41+00:00
After installing the Windows 10 April 2018 Update (Windows 10 version 1803), File Explorer cannot connect to other devices running version 1803.  When clicking the Network tab in File Explorer, other devices on the home network running version 1803 do not appear, and thus I’m not able to perform file sharing or access files on other devices on my home network.
2018-06-22T02:12:16+00:00
Microsoft is aware of reports that devices running Windows 10 version 1803 cannot connect to other devices on their home network and is investigating the issue.
You can resolve this problem by setting some services to Automatic (Delayed Start) and restarting Windows:
  1. Press the Windows Key and R at the same time to bring up the Run dialog.
  2. Type services.msc in the Run dialog and press Enter.
  3. For each of the following services, locate the service in list, right-click the service and select Properties.  Then set the Startup type to Automatic (Delayed Start) and select Apply.
    • Computer Browser (Browser)
    • Function Discovery Provider Host (FDPHost)
    • Function Discovery Resource Publication (FDResPub)
    • Network Connections (NetMan)
    • UPnP Device Host (UPnPHost)
    • Peer Name Resolution Protocol (PNRPSvc)
    • Peer Networking Grouping (P2PSvc)
    • Peer Networking Identity Manager (P2PIMSvc)
  4. Restart Windows.
Should you have any other concerns don't hesitate to post back.
240 additional answers
    2018-07-14T13:15:10+00:00
    Be assured that smbv1 is going away. Completely. It's getting disabled now for more than half a year. But you can reinstall it. Next step will be that you cannot reinstall, maybe in two years. Then you are forced to use a modern solution, anyway.
    I suggest you read that article I referenced, it answers your questions about security etc.
    File Sharing is the primary purpose of networking.
    And it works just fine without smbv1.
    Network Discovery is an integral part of the system.
    No, not really. But, anyway, you can have it without smbv1. As shown above.
  2. Deleted
    2018-07-14T16:07:43+00:00
    4. Restart Windows.
    The very first change Computer Browser will not accept Automatic (Delayed Start).  Gives Error 87.  Incorrect parameter.
    Makes me hesitant to change the others when your first step is incorrect.
    2018-07-14T17:27:28+00:00
    Just going to throw this out for information: blogs.technet.microsoft.com/filecab/2016/09/16/stop-using-smb1
    Link: Stop using SMB1 | Storage at Microsoft - Blogs TechNet
    This is the Microsoft developers commenting on SMB 1. Take it for what you will.
