File Explorer may not detect other devices or perform file sharing on the local network when running Windows 10 version 1803
2018-06-22T02:04:41+00:00
After installing the Windows 10 April 2018 Update (Windows 10 version 1803), File Explorer cannot connect to other devices running version 1803.  When clicking the Network tab in File Explorer, other devices on the home network running version 1803 do not appear, and thus I’m not able to perform file sharing or access files on other devices on my home network.
2018-06-22T02:12:16+00:00
Microsoft is aware of reports that devices running Windows 10 version 1803 cannot connect to other devices on their home network and is investigating the issue.
You can resolve this problem by setting some services to Automatic (Delayed Start) and restarting Windows:
  1. Press the Windows Key and R at the same time to bring up the Run dialog.
  2. Type services.msc in the Run dialog and press Enter.
  3. For each of the following services, locate the service in list, right-click the service and select Properties.  Then set the Startup type to Automatic (Delayed Start) and select Apply.
    • Computer Browser (Browser)
    • Function Discovery Provider Host (FDPHost)
    • Function Discovery Resource Publication (FDResPub)
    • Network Connections (NetMan)
    • UPnP Device Host (UPnPHost)
    • Peer Name Resolution Protocol (PNRPSvc)
    • Peer Networking Grouping (P2PSvc)
    • Peer Networking Identity Manager (P2PIMSvc)
  4. Restart Windows.
Should you have any other concerns don't hesitate to post back.
240 additional answers
  1. Deleted
    2018-07-08T17:05:20+00:00
    Followed the instructions step-by-step.  nothing, nada, zero ....zilch.
    2018-07-08T17:12:35+00:00
    Posting generic "it doesn't work" type replies won't help you. At all.
    Check out this good tutorial:
    https://answers.microsoft.com/en-us/windows/forum/windows_10-files/homegroup-removed-how-to-get-network-sharing-work/01277332-2916-4a68-853a-116696b20743
    If it doesn't help you, start your own thread and give detailed information including all steps you tried and everything you can find out about your network setup, IP no., hostnames, PCs, router brand, everything.
    2018-07-08T18:17:06+00:00
    Here are the details: the two pc's on my LAN are hostname Z370 and X99.  I have changed the Workgroup name to : MSHOME on both pc's.  X99 see's Z370 but gives error: windows cannot access \Z370.  Both are running W10 ver. 1803.  I have tried using the instructions posted by Pauli O, checked and double checked.  My router is an Asus RT-AC88U with the latest firmware.  I have set the router config under LAN, DHCP Server, Manually assign IP around DHCP; for both X99 and Z370.  I am just trying to test sharing on Documents folder only.  I have also tried the "Give access to", "Specific people" to "Everyone" both read and write.  Still no go.  Let me know if there is anything else  you need.  I just custom built the Z370 a couple of weeks ago and the Z99 is about three years old.
