File Explorer may not detect other devices or perform file sharing on the local network when running Windows 10 version 1803
2018-06-22T02:04:41+00:00
After installing the Windows 10 April 2018 Update (Windows 10 version 1803), File Explorer cannot connect to other devices running version 1803.  When clicking the Network tab in File Explorer, other devices on the home network running version 1803 do not appear, and thus I’m not able to perform file sharing or access files on other devices on my home network.
2018-06-22T02:12:16+00:00
Microsoft is aware of reports that devices running Windows 10 version 1803 cannot connect to other devices on their home network and is investigating the issue.
You can resolve this problem by setting some services to Automatic (Delayed Start) and restarting Windows:
  1. Press the Windows Key and R at the same time to bring up the Run dialog.
  2. Type services.msc in the Run dialog and press Enter.
  3. For each of the following services, locate the service in list, right-click the service and select Properties.  Then set the Startup type to Automatic (Delayed Start) and select Apply.
    • Computer Browser (Browser)
    • Function Discovery Provider Host (FDPHost)
    • Function Discovery Resource Publication (FDResPub)
    • Network Connections (NetMan)
    • UPnP Device Host (UPnPHost)
    • Peer Name Resolution Protocol (PNRPSvc)
    • Peer Networking Grouping (P2PSvc)
    • Peer Networking Identity Manager (P2PIMSvc)
  4. Restart Windows.
Should you have any other concerns don't hesitate to post back.
240 additional answers
  1. Deleted
    2018-07-04T18:07:04+00:00
    4. Restart Windows.
    I tried the temporary fix above and it did not help.  I have two desktop PC's with Windows 10 Pro and found out that Homegroup is no longer supported.  Both PC's are on the same workgroup and the network sharing's on both are set correctly and yet I cannot share files.  I sometimes see the shared PC and other times its not there.  If I see the share and try to open it, I get a cannot connect, cannot see share.  Made any progress on how to share files??  Mike
    2018-07-04T20:54:03+00:00
    Ich am Using win 10 pro and Home. Home ist Wirkung, bitte mit Pro.
    Greetings hpn.
    2018-07-04T22:39:07+00:00
    I wonder if Microsoft is looking into a better file sharing app.  I don't see OneDrive as a solution.  I am not familiar with OneDrive, but would like a local solution and not the Cloud.
