File Explorer may not detect other devices or perform file sharing on the local network when running Windows 10 version 1803
2018-06-22T02:04:41+00:00
After installing the Windows 10 April 2018 Update (Windows 10 version 1803), File Explorer cannot connect to other devices running version 1803.  When clicking the Network tab in File Explorer, other devices on the home network running version 1803 do not appear, and thus I’m not able to perform file sharing or access files on other devices on my home network.
2018-06-22T02:12:16+00:00
Microsoft is aware of reports that devices running Windows 10 version 1803 cannot connect to other devices on their home network and is investigating the issue.
You can resolve this problem by setting some services to Automatic (Delayed Start) and restarting Windows:
  1. Press the Windows Key and R at the same time to bring up the Run dialog.
  2. Type services.msc in the Run dialog and press Enter.
  3. For each of the following services, locate the service in list, right-click the service and select Properties.  Then set the Startup type to Automatic (Delayed Start) and select Apply.
    • Computer Browser (Browser)
    • Function Discovery Provider Host (FDPHost)
    • Function Discovery Resource Publication (FDResPub)
    • Network Connections (NetMan)
    • UPnP Device Host (UPnPHost)
    • Peer Name Resolution Protocol (PNRPSvc)
    • Peer Networking Grouping (P2PSvc)
    • Peer Networking Identity Manager (P2PIMSvc)
  4. Restart Windows.
Should you have any other concerns don't hesitate to post back.
240 additional answers
  1. Deleted
    2018-07-31T12:40:52+00:00
    {07/29/18 @ 14:47 EDT}
    Thanks to Microsoft for working on this problem.
    Problem: Three PCs are connected on a LAN
    • PCs 1 & 2 can see (device and files) each other but not PC3
    • PC3 can see all three PCs.
    How can PCs 1 & 2 see PC3?
    Running Avast Antivirus s/w Network Mapping, screenshot available, on PC2 shows all three PCs, but PC2 cannot see PC3 in File Explorer Network folder with Network Discovery enabled. Odd!
    The suggested changes did not solve the problem.
    Suggested additions to the procedure:
    • Sign in as Administrator (otherwise you cannot change settings)
    • Computer Browser does not allow Automatic (Delayed Start) so select Automatic
    PC3, which sees all thee PCs, has Manual entries for all of the services that are listed to change to Automatic (Delayed Start). This is also odd!
    Why does PC3 display the Network folder showing all three PCs in File Explorer with Network Discovery enabled while PC1 & 2 do not?
    Please have Microsoft continue to work on this because the solution has not been found for this Problem.
    Thanks Joules
    I do not understand this it is cryptic na din Jargon which I do not understand can someone who works for Microsoft Please help with this urgent question .All I want to do is have my Ethernet connected computers share file like they used to do with home group ???
    Please help now desperate.
  3. Deleted
    2018-07-30T13:11:24+00:00
    I tried a few more minor diddles.  They add nothing to the discussion.  Instead, thanks to StephenHayward26 for passing on his experience with security settings.  I have dodged  Microsoft's security system because it is complex, full of petty exceptions and is always changing.  The 1803 security settings must have been applied haphazardly to have left a machine  with 1803 stuffed into it (WARTHOG2-M, Table 4, configurations 4 and 5) still able to present its shares without  obstruction.  In any event, I have new path of inquiry I should have sought on my own.
    More telling still is that StephenHayward26 has given the lie  to Microsoft:  Its executives know about the file sharing/RDC problem and they knows what causes it.  Microsoft's deception has an antecedent.  During the Great Terror of 1936, soviet newspaper editorials moaned that "if only great Stalin knew of such things, he would give us justice."  Stalin wrote those editorials himself. He had a psychopath's criminality and a gift for finding people he could use for his own purposes.
    Microsoft has Stalin's talent for finding sincere, well-intentioned people like Jestoni Mac to spread what Microsoft knows is misleading bilge. Alas, Microsoft is incapable of Stalin's effrontery.  If Stalin ran Microsoft, we could measure our adversary more closely.  Instead, Microsoft hides behind silence and the wall of fear lodged in its hive mind as lawsuits yet unfiled infect its nightmares.  Meanwhile, thousands, millions of users nurse their anger and contempt.
