problem on 2018-04 cumulative update (KB4093112)
2018-04-11T13:15:46+00:00
Dear Sir,
my windows 10 64-bit version 1709 updating this KB4093112 updates in a loop, that is initializing, downloading (no download stream since the 2nd loop), installing (counting from 0% to 100%), after that, the installation restarting as a loop, what is wrong with that?
I tried restart my PC but nothing help
This workload keeps my CPU working in 60% and above, HDD working in 40% above somethings (max 100% before restart), RAM usage 45%.
Can anyone help on this?
hardware configuration:
Intel CPU i5-3450S 2.8GHz
RAM: 8GB
HDD: 1TB drive C; 2TB drive D with bitlocker locked
Display card: AMD Radeon R9 380
Mc
2018-04-11T20:45:45+00:00
I was getting an error code: 0x80070bc2 when trying to install KB4093112. Following this step help resolved my problem just minutes ago:
https://answers.microsoft.com/en-us/windows/forum/windows\_10-update/error-0x80070bc2-when-windows-10-update-trying-to/ba4053f2-acec-43db-9305-bca3cc2b8b0c
  • Right-click on Windows key and select Command Prompt (Admin).
  • Type the following commands in Command Prompt window. To execute them, press Enter after each one.
SC config wuauserv start= auto
SC config bits start= auto
SC config cryptsvc start= auto
SC config trustedinstaller start= auto
  • Finally, restart your PC and try to install the update that was previously returning the 0x80070bc2 error.
2018-04-19T07:49:27+00:00
Did you choose the right processor and the cumulative download?  It worked for me, Error 0x8024200d was gone after a reboot.
94 additional answers
    2018-04-14T15:38:14+00:00
    Thank you mike, it works flowless for me
    2018-04-14T21:34:23+00:00
    Good News:
    This solved my issue with the endless circle of the update failing to install. It installed both the KB4093112 update and the KB 4093110 (update to Adobe flash) after 14 trys. So I been able to free up the memory involved in constantly trying to update these.
    ====Thank You
    Bad News:
    Both of these still show as needing a restart to be finish installing, even though I have checked using the "About your PC" command and they show as the current os build.  Also the shut down options no longer show update and restart/shut down but simply give you to option to sleep, shut down, or restart.
    Do we know yet when this will go away? And before you ask: Yes, I have already tried an additional restart.
    2018-04-14T22:24:09+00:00
    I was able to get rid of the Cumulative Update using the above method, but the Adobe Flash Player update still shows waiting to restart to finish installing, even after about 10 tries, and doing troubleshooting windows update again, using the above method again, etc.  I do not see how to delete the update on my own.  When I tried to download the update manually, it says  I already have it installed.  I think the troubleshooter does delete the FP update but downloads a new copy and the problem continues.
    Any help, anybody?
    PS - On my system I have to enter CMD in the search window and enter cntrl+shift+enter.  Doing those commands in powershell as administrator shows an error that the positional argument "start=" is invalid, but not so using CMD.
