problem on 2018-04 cumulative update (KB4093112)
2018-04-11T13:15:46+00:00
Dear Sir,
my windows 10 64-bit version 1709 updating this KB4093112 updates in a loop, that is initializing, downloading (no download stream since the 2nd loop), installing (counting from 0% to 100%), after that, the installation restarting as a loop, what is wrong with that?
I tried restart my PC but nothing help
This workload keeps my CPU working in 60% and above, HDD working in 40% above somethings (max 100% before restart), RAM usage 45%.
Can anyone help on this?
hardware configuration:
Intel CPU i5-3450S 2.8GHz
RAM: 8GB
HDD: 1TB drive C; 2TB drive D with bitlocker locked
Display card: AMD Radeon R9 380
Mc
2018-04-11T20:45:45+00:00
I was getting an error code: 0x80070bc2 when trying to install KB4093112. Following this step help resolved my problem just minutes ago:
https://answers.microsoft.com/en-us/windows/forum/windows\_10-update/error-0x80070bc2-when-windows-10-update-trying-to/ba4053f2-acec-43db-9305-bca3cc2b8b0c
  • Right-click on Windows key and select Command Prompt (Admin).
  • Type the following commands in Command Prompt window. To execute them, press Enter after each one.
SC config wuauserv start= auto
SC config bits start= auto
SC config cryptsvc start= auto
SC config trustedinstaller start= auto
  • Finally, restart your PC and try to install the update that was previously returning the 0x80070bc2 error.
2018-04-19T07:49:27+00:00
Did you choose the right processor and the cumulative download?  It worked for me, Error 0x8024200d was gone after a reboot.
94 additional answers
    2018-05-07T15:53:09+00:00
    i have the same problem and it's f#cking annoying that i cannot install it....
    2018-05-07T22:04:49+00:00
    Sadly this did not help me because I get an auto return of [SC] OpenService FAILED 5: Access Denied.
    It didn't get past SC config wuauser start=auto.  "Positional parameter cannot be found that accepts argument 'start='
    I also have error 0x800f0922  and then 0x80070643.
    The install update is also KB4093105 NOT  KB4093112 Maybe we should figure out if we all have the same update and the same error first!
    Install update history should tell us what Update it is and the error code that resulted.
    Does Microsoft reimburse us for doing all this work?
    2018-05-07T23:26:14+00:00
    Hi Ac603xb,
    To know more about your issue, may we know what troubleshooting steps have you done so far? For the meantime, we suggest that you follow the steps provided on this link.
    Feel free to get back to us if you need further assistance.
