problem on 2018-04 cumulative update (KB4093112)
2018-04-11T13:15:46+00:00
Dear Sir,
my windows 10 64-bit version 1709 updating this KB4093112 updates in a loop, that is initializing, downloading (no download stream since the 2nd loop), installing (counting from 0% to 100%), after that, the installation restarting as a loop, what is wrong with that?
I tried restart my PC but nothing help
This workload keeps my CPU working in 60% and above, HDD working in 40% above somethings (max 100% before restart), RAM usage 45%.
Can anyone help on this?
hardware configuration:
Intel CPU i5-3450S 2.8GHz
RAM: 8GB
HDD: 1TB drive C; 2TB drive D with bitlocker locked
Display card: AMD Radeon R9 380
Mc
2018-04-11T20:45:45+00:00
I was getting an error code: 0x80070bc2 when trying to install KB4093112. Following this step help resolved my problem just minutes ago:
https://answers.microsoft.com/en-us/windows/forum/windows\_10-update/error-0x80070bc2-when-windows-10-update-trying-to/ba4053f2-acec-43db-9305-bca3cc2b8b0c
  • Right-click on Windows key and select Command Prompt (Admin).
  • Type the following commands in Command Prompt window. To execute them, press Enter after each one.
SC config wuauserv start= auto
SC config bits start= auto
SC config cryptsvc start= auto
SC config trustedinstaller start= auto
  • Finally, restart your PC and try to install the update that was previously returning the 0x80070bc2 error.
2018-04-19T07:49:27+00:00
Did you choose the right processor and the cumulative download?  It worked for me, Error 0x8024200d was gone after a reboot.
94 additional answers
    2018-04-27T19:41:27+00:00
    Hi AudiS4, yes it was having a different error message, but using Troys procedure, I managed to successfully load the update manually. It has not fixed some other bugs that are lingering, but was the only way I could install the update.
    Hopefully on the next Patch Tuesday, we'll get the issues resolved before Microsoft introduce some more gothcha's.
    Did you try a downlrad from the Catalogue and manually install?
    Cheers
    2018-04-28T11:49:08+00:00
    Thank you so much TroyKemp.  This solved the problem for me and I am so very grateful.  I am really frustrated that Microsoft are constantly causing people so many problems with their updates.  Many many thanks to you.  Sue x
    2018-05-03T03:36:37+00:00
    Sadly this did not help me because I get an auto return of [SC] OpenService FAILED 5: Access Denied.
