problem on 2018-04 cumulative update (KB4093112)
2018-04-11T13:15:46+00:00
Dear Sir,
my windows 10 64-bit version 1709 updating this KB4093112 updates in a loop, that is initializing, downloading (no download stream since the 2nd loop), installing (counting from 0% to 100%), after that, the installation restarting as a loop, what is wrong with that?
I tried restart my PC but nothing help
This workload keeps my CPU working in 60% and above, HDD working in 40% above somethings (max 100% before restart), RAM usage 45%.
Can anyone help on this?
hardware configuration:
Intel CPU i5-3450S 2.8GHz
RAM: 8GB
HDD: 1TB drive C; 2TB drive D with bitlocker locked
Display card: AMD Radeon R9 380
Mc
2018-04-11T20:45:45+00:00
I was getting an error code: 0x80070bc2 when trying to install KB4093112. Following this step help resolved my problem just minutes ago:
https://answers.microsoft.com/en-us/windows/forum/windows\_10-update/error-0x80070bc2-when-windows-10-update-trying-to/ba4053f2-acec-43db-9305-bca3cc2b8b0c
  • Right-click on Windows key and select Command Prompt (Admin).
  • Type the following commands in Command Prompt window. To execute them, press Enter after each one.
SC config wuauserv start= auto
SC config bits start= auto
SC config cryptsvc start= auto
SC config trustedinstaller start= auto
  • Finally, restart your PC and try to install the update that was previously returning the 0x80070bc2 error.
2018-04-19T07:49:27+00:00
Did you choose the right processor and the cumulative download?  It worked for me, Error 0x8024200d was gone after a reboot.
94 additional answers
    2018-04-19T13:51:33+00:00
    If SC doesn't work, try typing sc.exe instead.
    2018-04-19T19:26:00+00:00
    You can even copy these commands and make a batch file out of them. This worked great for me! Hours banging my head on my desk figuring out why this stupid update kept looping. Now it's finally going through the install stages.
    d-(^_^)z
    2018-04-20T05:40:59+00:00
    Dear BertNiemeijer,
    Thanks for your reminder, my fault, i have just downloaded the first one...
    I downloaded the right one and installed manually, after 1 reboot, and i checked again the windows update, it tells me KB4093112 installed successfully and my system is up to date!!
    Thank you all who provided suggestions and wish others can check this topic and got a solution for the issue.
    Thanks!
    Regards,
    Mc
