problem on 2018-04 cumulative update (KB4093112)
2018-04-11T13:15:46+00:00
Dear Sir,
my windows 10 64-bit version 1709 updating this KB4093112 updates in a loop, that is initializing, downloading (no download stream since the 2nd loop), installing (counting from 0% to 100%), after that, the installation restarting as a loop, what is wrong with that?
I tried restart my PC but nothing help
This workload keeps my CPU working in 60% and above, HDD working in 40% above somethings (max 100% before restart), RAM usage 45%.
Can anyone help on this?
hardware configuration:
Intel CPU i5-3450S 2.8GHz
RAM: 8GB
HDD: 1TB drive C; 2TB drive D with bitlocker locked
Display card: AMD Radeon R9 380
Mc
2018-04-11T20:45:45+00:00
I was getting an error code: 0x80070bc2 when trying to install KB4093112. Following this step help resolved my problem just minutes ago:
https://answers.microsoft.com/en-us/windows/forum/windows\_10-update/error-0x80070bc2-when-windows-10-update-trying-to/ba4053f2-acec-43db-9305-bca3cc2b8b0c
  • Right-click on Windows key and select Command Prompt (Admin).
  • Type the following commands in Command Prompt window. To execute them, press Enter after each one.
SC config wuauserv start= auto
SC config bits start= auto
SC config cryptsvc start= auto
SC config trustedinstaller start= auto
  • Finally, restart your PC and try to install the update that was previously returning the 0x80070bc2 error.
2018-04-19T07:49:27+00:00
Did you choose the right processor and the cumulative download?  It worked for me, Error 0x8024200d was gone after a reboot.
94 additional answers
    2018-04-19T05:13:54+00:00
    Has anyone found a fix that works on Error 0x8024200d for the win 10 update-kb4093112? Considering the number of people getting this error, is Microsoft working on a patch? Or are we on our own? Please keep us in the loop Microsoft techs.
    Dear AshrafLobo,
    I've got the same issue and the numbers of retry is now 83.
    i tried all suggestions under this topic, it all NOT working for me.
    i wish MS is working on it.
    thx
    rgds,
    Mc
    2018-04-19T05:23:50+00:00
    Download and install in manually:
    https://www.catalog.update.microsoft.com/Search.aspx?q=KB4093112
    (in my case I needed to try it twice)
    Cheers
    Dear BertNiegeijer,
    i downloaded manually the KB4093112, after i double clicked this files, it tells me:
    the update is not applicable to your computer
    Holly! if it really not applicable, why it keeps running in a loop?!
    anyway, thx for your suggestion, wish MS is working on it.
    thx
    rgds,
    Mc
    2018-04-19T10:21:17+00:00
    I was being slowly driven mad by this problem. I also had the "Some settings are managed by your organizational" issue. I had spent days scouring the Web looking for a fix. Lots of sites promised to fix it, but none did. Until I came across this. This fix sorted both problems out and my pc is working perfectly again. And I know what to do if it ever happens again. Well done.
