problem on 2018-04 cumulative update (KB4093112)
2018-04-11T13:15:46+00:00
Dear Sir,
my windows 10 64-bit version 1709 updating this KB4093112 updates in a loop, that is initializing, downloading (no download stream since the 2nd loop), installing (counting from 0% to 100%), after that, the installation restarting as a loop, what is wrong with that?
I tried restart my PC but nothing help
This workload keeps my CPU working in 60% and above, HDD working in 40% above somethings (max 100% before restart), RAM usage 45%.
Can anyone help on this?
hardware configuration:
Intel CPU i5-3450S 2.8GHz
RAM: 8GB
HDD: 1TB drive C; 2TB drive D with bitlocker locked
Display card: AMD Radeon R9 380
Mc
2018-04-11T20:45:45+00:00
I was getting an error code: 0x80070bc2 when trying to install KB4093112. Following this step help resolved my problem just minutes ago:
https://answers.microsoft.com/en-us/windows/forum/windows\_10-update/error-0x80070bc2-when-windows-10-update-trying-to/ba4053f2-acec-43db-9305-bca3cc2b8b0c
  • Right-click on Windows key and select Command Prompt (Admin).
  • Type the following commands in Command Prompt window. To execute them, press Enter after each one.
SC config wuauserv start= auto
SC config bits start= auto
SC config cryptsvc start= auto
SC config trustedinstaller start= auto
  • Finally, restart your PC and try to install the update that was previously returning the 0x80070bc2 error.
2018-04-19T07:49:27+00:00
Did you choose the right processor and the cumulative download?  It worked for me, Error 0x8024200d was gone after a reboot.
94 additional answers
    2018-04-18T08:08:07+00:00
    What I have noticed is that when the machine restarts, it will come up with a message something like
    Installing stage 2 of XX    --- where XX is a decreasing number on each reboot.  Started at 102 and is now down to 97.
    I also noticed that there are some Dcom errors in the eventlog, looks like permission errors
    Yes, very similar symptoms here. There have been permission errors around DCOM for years so that might be a red herring.
    2018-04-18T08:43:16+00:00
    Download and install in manually:
    https://www.catalog.update.microsoft.com/Search.aspx?q=KB4093112
    (in my case I needed to try it twice)
    Cheers
    Thanks, BertNiemeijer this solved my Error 0x8024200d
    2018-04-18T17:46:10+00:00
    Well I finally got the VM updated using a combination of nearly every suggestion. If I'd got all the time in the world, I'd go back to the snapshot to try and repeat but in the end it was a mad combination of:
    1. Changing the four services mentioned above to auto - note... Windows keeps resetting the start mode for the bits service to manual
    2. Stopping the wuauserv and bits services and then deleting the SoftwareDistribution folder
    3. Rebooting many times
    4. Installing the update manually
    On the last attempt, I ran the PowerShell script below, installed KB4093112 (Apr 2018 updates) manually and rebooted - at least twice. First time it installed a few things but still said a restart was needed so another restart installed some more stuff and finally said "Up to date" with winver showing Version 1709 (OS Build 16299.371).
    What a palaver!
    Fix-WindowsUpdate.ps1 - attempts to repair culmulative update failures.
    Check running as administrator.
    $User = [Security.Principal.WindowsIdentity]::GetCurrent()
    If (!((New-Object Security.Principal.WindowsPrincipal $User).IsInRole([Security.Principal.WindowsBuiltinRole]::Administrator))) {
     Write-Host -Fore Red "Please run as administrator"
     Return
    Change services to auto but also stop them.
    $ServiceNames = @("wuauserv","bits","cryptsvc","trustedinstaller")
    ForEach ($ServiceName In $ServiceNames) {
     $Service = Get-Service -Name $ServiceName
     If ($Service.StartType -ne "Automatic") {
      Write-Host "Changing $ServiceName to automatic"
      $Cmd = "cmd /c SC config $ServiceName start= auto"
      Invoke-Expression $Cmd
     # Write-Host "$ServiceName`: $($Service.Status)"
     If ($Service.Status -eq "Running") {
      Write-Host "Stopping $ServiceName"
      $Service | Stop-Service
    Delete software distribution folder.
    $Path = $Env:WinDir + "\SoftwareDistribution"
    If (Test-Path $Path) {
     Write-Host "Removing $Path"
     Remove-Item -Path $Path -Recurse -Force
    If (Test-Path $Path) {Write-Host -Fore Yellow "WARNING: folder not entirely deleted"}
    Finished.
    Write-Host -Fore Yellow "Run again if errors, otherwise restart"
