problem on 2018-04 cumulative update (KB4093112)
2018-04-11T13:15:46+00:00
Dear Sir,
my windows 10 64-bit version 1709 updating this KB4093112 updates in a loop, that is initializing, downloading (no download stream since the 2nd loop), installing (counting from 0% to 100%), after that, the installation restarting as a loop, what is wrong with that?
I tried restart my PC but nothing help
This workload keeps my CPU working in 60% and above, HDD working in 40% above somethings (max 100% before restart), RAM usage 45%.
Can anyone help on this?
hardware configuration:
Intel CPU i5-3450S 2.8GHz
RAM: 8GB
HDD: 1TB drive C; 2TB drive D with bitlocker locked
Display card: AMD Radeon R9 380
Mc
2018-04-11T20:45:45+00:00
I was getting an error code: 0x80070bc2 when trying to install KB4093112. Following this step help resolved my problem just minutes ago:
https://answers.microsoft.com/en-us/windows/forum/windows\_10-update/error-0x80070bc2-when-windows-10-update-trying-to/ba4053f2-acec-43db-9305-bca3cc2b8b0c
  • Right-click on Windows key and select Command Prompt (Admin).
  • Type the following commands in Command Prompt window. To execute them, press Enter after each one.
SC config wuauserv start= auto
SC config bits start= auto
SC config cryptsvc start= auto
SC config trustedinstaller start= auto
  • Finally, restart your PC and try to install the update that was previously returning the 0x80070bc2 error.
2018-04-19T07:49:27+00:00
Did you choose the right processor and the cumulative download?  It worked for me, Error 0x8024200d was gone after a reboot.
94 additional answers
    2018-04-17T21:25:08+00:00
    And the final one of the night, executing just this command from elevated command prompt:
    And one reboot and the updates started to install...
    2018-04-17T22:26:04+00:00
    Ohh hang on - I spoke too soon. Whilst changing the services to auto did allow some updates to install, they weren't the April updates. I had a "Your device is up to date" but when I checked back an hour later, it's now trying to download the April updates again :-(
    2018-04-18T02:39:59+00:00
    I also have an issue with loop with KB4093112 which fails to install with the below error taken from the System log
    Installation Failure: Windows failed to install the following update with error 0x800F0922: 2018-04 Cumulative Update for Windows 10 Version 1709 for x64-based Systems (KB4093112).
    I have tried the usual fixes with Windows update recovery but everytime reboots the same..
    The error code is different to other being 0x800F0922
    Any help appreciated.
    PJ_W
