problem on 2018-04 cumulative update (KB4093112)
2018-04-11T13:15:46+00:00
Dear Sir,
my windows 10 64-bit version 1709 updating this KB4093112 updates in a loop, that is initializing, downloading (no download stream since the 2nd loop), installing (counting from 0% to 100%), after that, the installation restarting as a loop, what is wrong with that?
I tried restart my PC but nothing help
This workload keeps my CPU working in 60% and above, HDD working in 40% above somethings (max 100% before restart), RAM usage 45%.
Can anyone help on this?
hardware configuration:
Intel CPU i5-3450S 2.8GHz
RAM: 8GB
HDD: 1TB drive C; 2TB drive D with bitlocker locked
Display card: AMD Radeon R9 380
Mc
2018-04-11T20:45:45+00:00
I was getting an error code: 0x80070bc2 when trying to install KB4093112. Following this step help resolved my problem just minutes ago:
https://answers.microsoft.com/en-us/windows/forum/windows\_10-update/error-0x80070bc2-when-windows-10-update-trying-to/ba4053f2-acec-43db-9305-bca3cc2b8b0c
  • Right-click on Windows key and select Command Prompt (Admin).
  • Type the following commands in Command Prompt window. To execute them, press Enter after each one.
SC config wuauserv start= auto
SC config bits start= auto
SC config cryptsvc start= auto
SC config trustedinstaller start= auto
  • Finally, restart your PC and try to install the update that was previously returning the 0x80070bc2 error.
2018-04-19T07:49:27+00:00
Did you choose the right processor and the cumulative download?  It worked for me, Error 0x8024200d was gone after a reboot.
94 additional answers
    2018-04-17T20:55:07+00:00
    Hi TroyKemp1,
    Before this solution finlay worked, I had to  :
    • Create a new (admin) microsoft account on my PC
    • Restart the PC
    • Login with the newly created Microsoft account
    • Apply your solution with the 4 SC command
    • Restard the PC again
    • Relloged into the Microsoft admin account
    • Finaly the update went thru
    • Relloged to my local admin account
    • Delete the microsoft admin account just created to apply the update.
    Hope this might help other users since nothing worked for me before I decided to create a new admin account (Microsoft).  Because I coudn't create a local admin account on my PC.
    Regards
    2018-04-17T21:03:23+00:00
    Okay, definitely wasn't coincidence - went back to prior to the SC commands, didn't run them and rebooted three times waiting for update each time. Always failed. So back to snapshot again to try SC commands again...
    2018-04-17T21:20:52+00:00
    Yup confirmed, changing start mode for BITS and TrusterInstaller to auto and the update installs after two reboots.
