problem on 2018-04 cumulative update (KB4093112)
2018-04-11T13:15:46+00:00
Dear Sir,
my windows 10 64-bit version 1709 updating this KB4093112 updates in a loop, that is initializing, downloading (no download stream since the 2nd loop), installing (counting from 0% to 100%), after that, the installation restarting as a loop, what is wrong with that?
I tried restart my PC but nothing help
This workload keeps my CPU working in 60% and above, HDD working in 40% above somethings (max 100% before restart), RAM usage 45%.
Can anyone help on this?
hardware configuration:
Intel CPU i5-3450S 2.8GHz
RAM: 8GB
HDD: 1TB drive C; 2TB drive D with bitlocker locked
Display card: AMD Radeon R9 380
Mc
2018-04-11T20:45:45+00:00
I was getting an error code: 0x80070bc2 when trying to install KB4093112. Following this step help resolved my problem just minutes ago:
https://answers.microsoft.com/en-us/windows/forum/windows\_10-update/error-0x80070bc2-when-windows-10-update-trying-to/ba4053f2-acec-43db-9305-bca3cc2b8b0c
  • Right-click on Windows key and select Command Prompt (Admin).
  • Type the following commands in Command Prompt window. To execute them, press Enter after each one.
SC config wuauserv start= auto
SC config bits start= auto
SC config cryptsvc start= auto
SC config trustedinstaller start= auto
  • Finally, restart your PC and try to install the update that was previously returning the 0x80070bc2 error.
2018-04-19T07:49:27+00:00
Did you choose the right processor and the cumulative download?  It worked for me, Error 0x8024200d was gone after a reboot.
94 additional answers
    2018-04-17T19:53:47+00:00
    Has anyone found a fix that works on Error 0x8024200d for the win 10 update-kb4093112? Considering the number of people getting this error, is Microsoft working on a patch? Or are we on our own? Please keep us in the loop Microsoft techs.
    2018-04-17T20:20:58+00:00
    Hmm, interesting but this also worked for me. I've got a VMware virtual machine that's singularly failed to install cumulative updates for the past four months. I took a snapshot of the VM before I tried the above so I'm going to restore that image and see what state the services were in before. All the above commands are doing is changing the start-up mode of some services to automatic. This suggests that one/some of them are not in automatic start-up already. If it's that simple, Microsoft need a dressing down as it's a simple fix.
    It could be though that this is coincidence because some have reported that sometimes April update finally works after several attempts.
    As I write, it's not quite finished the update - about 3rd reboot with lots of much more encouraging update messages.
    2018-04-17T20:38:43+00:00
    Later... yes, April updates installed. Restored the VM prior to the SC commands and checked the services:
    wuauserv - already auto
    bits start - manual so SC command is changing this to auto
    cryptsvc - already auto
    trustedinstaller - manual so SC command is changing this to auto
    So changing bits and trustedinstaller to auto is the fix (need to double check). Bits is a service that downloads updates from the internet (background intelligent transfer service) and has been around for ages. Trustedinstaller crops up less often and I'm going to point my finger in this direction been set to manual.
    More later...
