problem on 2018-04 cumulative update (KB4093112)
2018-04-11T13:15:46+00:00
Dear Sir,
my windows 10 64-bit version 1709 updating this KB4093112 updates in a loop, that is initializing, downloading (no download stream since the 2nd loop), installing (counting from 0% to 100%), after that, the installation restarting as a loop, what is wrong with that?
I tried restart my PC but nothing help
This workload keeps my CPU working in 60% and above, HDD working in 40% above somethings (max 100% before restart), RAM usage 45%.
Can anyone help on this?
hardware configuration:
Intel CPU i5-3450S 2.8GHz
RAM: 8GB
HDD: 1TB drive C; 2TB drive D with bitlocker locked
Display card: AMD Radeon R9 380
Mc
2018-04-11T20:45:45+00:00
I was getting an error code: 0x80070bc2 when trying to install KB4093112. Following this step help resolved my problem just minutes ago:
https://answers.microsoft.com/en-us/windows/forum/windows\_10-update/error-0x80070bc2-when-windows-10-update-trying-to/ba4053f2-acec-43db-9305-bca3cc2b8b0c
  • Right-click on Windows key and select Command Prompt (Admin).
  • Type the following commands in Command Prompt window. To execute them, press Enter after each one.
SC config wuauserv start= auto
SC config bits start= auto
SC config cryptsvc start= auto
SC config trustedinstaller start= auto
  • Finally, restart your PC and try to install the update that was previously returning the 0x80070bc2 error.
2018-04-19T07:49:27+00:00
Did you choose the right processor and the cumulative download?  It worked for me, Error 0x8024200d was gone after a reboot.
94 additional answers
    2018-04-15T07:18:18+00:00
    Dear Bartek Paczkowski,
    hope this really worth to wait, the windows update for KB4093112 keeps running in a loop everytime a restart / start the PC.
    I've tried once again all method i have tired here with a restart, but still did not work for me.
    Today, i turn on my PC and check the status of windows update, it told me
    update ready to be install with a button "install updates", i press this button, after installation, then a loop start again, i.e. initialising... -> downloading -> installing with % count -> initialising...
    I keep checking with the task manager, it consumes 50% disk workload and max 40% CPU workload.
    I hope you are true, one day i turn on my PC, and this issue solved, i hope so...
    Again, i have to "end task" for "Windows Update", "Update Orchestrator Service" and "Remote Access Connection Manager" to stop it from consuming my PC
    thx
    rgds,
    Mc
    2018-04-15T07:27:11+00:00
    MC same thing here also this is BAD FORM MICROSOFT STOP MAKING THE PUBLIC GUINEA PIGS!
    When I have run every Microsoft fix including command line fixes nothing works then fix it! Ran SFC nothing DISM nothing SC wuserv- auto Nothing fixing this issue. Not errors in event viewer except the failing of the kb4093112 update. No viruses or spyware on the machine no known permission issues. COME ON MAN! The manual updates look like they are only for AMD systems since when I manually run these and they say not for this system! Uninstalled my AV nothing. Computer keeps looping from this and failing. By the way no bad hardware either.
    https://www.catalog.update.microsoft.com/Search.aspx?q=KB4093112
    Dear tdrknt,
    seems we have nothing to do with that and may be just wait...
    everytime i start my PC, the first thing i need to do is to end task the windows update so it did not consume the resources...
    i checked again what KB4093112 involves, it mainly improvement for AMD CPU issues, IE, App-V, RDS server and with security updates for windows and seems the security updates is my only concern...
    wish Microsoft is working on this issue...
    thx
    rgds,
    Mc
    2018-04-15T21:46:53+00:00
    Thanks for verifying that information. I do see that you also have done all the troubleshooting steps provided by the community members and still you are experiencing the same error. It's possible that your current user profile is corrupted causing conflicts in installing the Windows update properly.
    In that case, I suggest that you create a new administrator account first. Sign in to your new profile then perform a clean boot. Follow the steps carefully stated in this article to perform clean boot: How to perform a clean boot in Windows.
    Once you have performed a clean boot, check for Windows update by clicking on Start > Settings > Update & security > Windows Update, and select Check for updates. If it does not push through, run the Windows update troubleshooter.
    Update us with the results as soon as possible.
