Screen brightness stuck at max after updating to Windows 10 version 1803 (build 17134 / April 2018 Update)
2018-04-30T22:07:35+00:00
Hi
I just updated the Windows 10 Home installation on my laptop to build 17134 and now I can't adjust the screen brightness. It's stuck at the highest brightness setting and while the brightness slider moves up and down it doesn't change anything. I tried deleting the display and graphic drivers and reinstall them but it didn't solve my problem. My laptop is an old lady so it no longer receives driver updates. Any suggestions?
Specs: https://support.hp.com/ee-en/document/c02286076
HP Envy 14-1090eo
2.4 GHz Intel Core i5-450M
ATI Mobility Radeon HD 5650 1GB DDR3 (Switchable)
8GB (2x4GB) Samsung PC3-12800 DDR3
Samsung SSD 850 EVO 1TB
Display drivers:
- 1. Primary: Intel® HD Graphics (Core i5)
Report Date: 4/30/2018
Report Time[hr:mm:ss]: 23:53:55
Driver Version: 8.15.10.2900
Operating System: (6.2.9200)
Default Language: English (United States)
DirectX* Version: 10.1
Physical Memory: 7989 MB
Minimum Graphics Memory: 32 MB
Maximum Graphics Memory: 973 MB
Graphics Memory in Use: 115 MB
Processor: Intel64 Family 6 Model 37 Stepping 5
Processor Speed: 2394 MHz
Vendor ID: 8086
Device ID:  0046
Device Revision: 02
**- 2. Secondary:**ATI Mobility Radeon HD 5650
Radeon Settings Version - 2016.0226.1531.27895
Driver Packaging Version - 15.301.1901-160226a-299900E
Provider - Advanced Micro Devices, Inc.
2D Driver Version - 8.1.1.1533
Direct3D® Version - 9.14.10.1171
OpenGL® Version - 6.14.10.13417
OpenCL™ Version - 2.0.4.0
AMD Mantle Version - 9.1.10.99
AMD Mantle API Version - Not Available
AMD Audio Driver Version - 10.0.0.3
Update May 25, 2018:
This solution from Ferdz Amp with a minor tweak solved my problem.
For those still encountering this issue, I recommend that you follow these steps and see if the issue persists:
  1. In Windows start search box, type in regedit and hit Enter.
  2. Navigate to the following key:
    • HKEY_LOCAL_MACHINE/SYSTEM/ControlSet001/Control/Class/ 4d36e968-e325-11ce-bfc1-08002be10318 /0000
  3. Double-click the item of FeatureTestControl, set the hexadecimal value to "fb20", and click OK.
  4. Reboot your computer to reflect the changes.
Registry Disclaimer: The steps mentioned here includes system registry modification. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow the steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: Article ID 322756.
Let me know how it goes.
The written location for FeatureTestControl was different on my system. The location is:
  • HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class{4d36e968-e325-11ce-bfc1-08002be10318}\0001
Please be aware that after doing this edit, selecting the lowest level of brightness will turn off your screen. This also means that if you are running on battery (laptop) and you select the power mode "Best battery life" or Windows automatically switches to "Best battery life" upon unplugging the charger, your screen will be turned OFF! This is not a major concern since you can just turn up the brightness to the next lowest level via the FN+F3 (key combo might differ on other laptop brands) keyboard control shortcut and the screen will be turned back ON.
2018-05-25T09:31:54+00:00
Hi
HP Envy 14-1090eo
Display drivers:
Vendor ID: 8086
Device ID:  0046
Device Revision: 02
Moved from ( Windows / Windows 10 / Windows update, recovery, & backup )
did new cumulative update fixed brightness issue?
No KB4100403 (OS Build 17134.81) didn't solve it. But this solution from Ferdz Amp with a minor tweak did.
The written location for FeatureTestControl was different on my system and is located in:
Please be aware that after doing this edit selecting the lowest level of brightness will turn off your screen. This also means that if you are running on battery (laptop) and you select the power mode "Best battery life" or Windows automatically switches to "Best battery life" upon unplugging the charger, your screen will be turned OFF! This is not a major concern since you can just turn up the brightness to the next lowest level via the FN+F3 (key combo might differ on other laptop brands) keyboard control shortcut and the screen will be turned back ON.
78 additional answers
    2018-05-23T22:07:36+00:00
    THIS IS WHAT FIXED THE ISSUE FOR ME (Date: 23rd May 2018):
    1. I opened Device Manager.
    2. Noticed that Display Adapters section was reporting problem (showing exclamation sign) for the "Intel HD Graphics 620". (This solution may work for other onboard graphics too).
    3. I right clicked on that and chose "Update driver" option.
    4. On the pop-up window, I chose "Search automatically for updated driver software" option.
    5. Windows searched and automatically installed the driver software over Internet and the Brightness Controls started working again immediately (without restarting the PC).
    6. Device Manager also stopped reporting problem with Display Adapter.
    I hope this helps some of you if not all of you.
    Please keep in mind that that HD Graphics 620 is a Kaby Lake part (7/8th generation Intel Core processors), which still gets its drivers updated regularly by Intel. This solution doesn't work on 1st gen Intel HD Graphics (or earlier Intel based graphic chips) as they all use Windows 7 drivers since proper Windows 10 drivers doesn't exist. The Arrandale-based processor family with 1st gen HD Graphics was EOL when Windows 10 was released but Windows 10 was still stuffed down our throats.
    2018-05-23T22:10:18+00:00
    I have the same problem on Toshiba C650 T9300 and eMachines E372Z i7 640M
    Ja mam Toshibe C650 z intel mobile 4 family i eMachines z i7 jakiś intelowy HD na obu problem z regulacją.... świeci jak choinka.... co mam sprawdzić ?
    Może gdzieś na priv potestujemy zanim tu offtopa zrobimy po Polsku :-)
    2018-05-23T22:21:24+00:00
    After a few days of work I finally found a solution for my laptop
    HP Pavilion dv6-3120ew 1st Gen Intel HD Graphics).
    Be careful about registry !!! Make backup of them before !!!!
    You have two choices:
    1. You may disable Intel Display Power Saving
    **https://mikebattistablog.wordpress.com/2016/05/27/disable-intel-dpst-on-sp4/**.
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class{4d36e968-e325-11ce-bfc1-08002be10318}\000x] (x=0/1/2) "FeatureTestControl"=dword:00009240
    1. or set a proper value (depends on model of your notebook - see bellow ) of FeatureTestControl registry key of your notebook.
    On my machine I have to tune this one
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class{4d36e968-e325-11ce-bfc1-08002be10318}\0002] "FeatureTestControl"=dword:f810(I changed it to f942 )
    (in an article is .........Class{4d36e968-e325-11ce-bfc1-08002be10318}*0000*......)
    Curiosity my old value FeatureTestControl=f810 (from Windows Fall Creators Update) doesn't work
    I had to change it to **FeatureTestControl=**f942.
    What did you change in your kernel, Microsoft ? Is it a bug ? Quod erat demonstrandum !!!
    Good luck. Bye C
    Additional readings:
    Bellow a list of proper value for many notebooks
    https://docs.google.com/spreadsheets/d/1qBer\_p2xJVnYqG7T\_GjYZf7CcdKo6SEwrMvApXkF\_7g/pub
    If you want to examine your previous setting make a copy windows.old\system32\config\system file and load it in regedit (load hive). Remember after finishing a task - unload added hive.
    A to zadziała na Intel GM 4 ?
    2018-05-23T22:28:16+00:00
    Run ASAP Microsoft !!! Go quickly to work, fix Your mistake !!!
    Infolinia i pomoc techniczna Microsoft Polska to jakaś kpina... usłyszałem że "wersja v1803 jest zbyt wymagająca dla mojego sprzętu" laski z telemarketingu mają wiecej profesjonalizmu...
