After installation of KB4056892 boot failure, after roll-back error 0x800f0845
2018-01-04T22:13:27+00:00
I have older AMD Athlon 64 X2 6000+, Asus MB, after installation of KB4056892 the system doesn't boot, it only shows the Windows logo without animation and nothing more. After several failed boots it do roll-back then it shows error 0x800f0845. Unfortunately, it seems it's not easy to disable the automatic updates without gpedit tweaks, so it tries installing and rolling-back the update over and over. The sfc /scannow shows no problem, in-place upgrade also doesn't seem to help. I can try full reinstall, but I doubt it will change anything. It seems like the update is binary incompatible with my old CPU. I understand that making the machine unbootable is the best protection from remote exploitation, but I would rather have the OS working. Especially if my CPU is not vulnerable to the Meltdown attack and the MS mitigation attempts for Spectre is more than questionable. I could find only some German and Italian people reporting the same issue (well the CPU is quite pre-historic and the KB update is very fresh), but no info / acknowledgment from the MS so far. I have Czech localization. Could anybody provide more information?
    2018-02-02T19:05:12+00:00
    KB4056892 is not bundled with 1709, seems you are experiencing other issue related with an older Windows 10 version.
    2018-02-02T19:33:20+00:00
    Interesting. In that case, then I'm experiencing issues related to a newerWindows 10 version. 1607 works just fine and updates accordingly. It's 1709 that seems to have issues.
    2018-02-02T19:36:43+00:00
    for Windows 10 1607 you have to install KB4057142 to fix the boot failure.
    2018-02-02T20:01:32+00:00
    Melerix
    I am wondering if problems with these AMD "A" series processors ( example knight1fox3 )  should be addresses in a different thread.  They are something of a different animal as they have an internal graphics adapter.
    From wikipedia........
    Steamroller architecture (2014): Kaveri
    Main article: Steamroller (microarchitecture)
    • Steamroller-based CPU with 2–4 cores[62]
    • Graphics Core Next 2nd Gen-based GPU with 192–512 shader processors[63]
    • 15–95 W thermal design power[62][63]
    • Fastest mobile processor of this series: AMD FX-7600P (35 W)
    • Fastest desktop processor of this series: AMD A10-7850K (95 W)
    • Socket FM2+ and Socket FP3[62]
    • Target segment desktop and mobile
    • Heterogeneous System Architecture-enabled zero-copying through pointer passing
    The third generation of the platform, codenamed Kaveri, was partly released on January 14, 2014.[64] Kaveri contains up to four Steamroller CPU cores clocked to 3.9 GHz with a turbo mode of 4.1 GHz, up to a 512-core Graphics Core Next GPU, two decode units per module instead of one (which allows each core to decode four instructions per cycle instead of two), AMD TrueAudio,[65] Mantle API,[66] an on-chip ARM Cortex-A5 MPCore,[67] and will release with a new socket, FM2+.[68] Ian Cutress and Rahul Garg of Anandtech asserted that Kaveri represented the unified system-on-a-chip realisation of AMD's acquisition of ATI. The performance of the 45 W A8-7600 Kaveri APU was found to be similar to that of the 100 W Richland part, leading to the claim that AMD made significant improvements in on-die graphics performance per watt;[62] however, CPU performance was found to lag behind similarly-specified Intel processors, a lag that was unlikely to be resolved in the Bulldozer family APUs.[62] The A8-7600 component was delayed from a Q1 launch to an H1 launch because the Steamroller architecture components were allegedly did not scale well at higher clock speeds.
    https://en.wikipedia.org/wiki/AMD_Accelerated_Processing_Unit
    Although "fx" series vintage, I wonder if these "A" series CPUs might have slipped through a crack.
    2018-02-02T20:33:22+00:00
    So just for my understanding, you're suggesting that I install KB4057142 while currently using the Win 10 1607 build, then attempt to re-install build 1709 and hopefully that will eliminate the boot failure issue(s)?
