If it were my PC I would just allow it to roll through the updates without intervening, as you have managed to debug the problem and can always backout to that point again.
Did you actually run a chkdsk or scan in the end? That problem seemed like it could be corruption of either video management software or video drivers, perhaps one of the patches caused the problem ..it wouldn't hurt running a chkdsk or scan too look for
bad disk sectors.
Agreed. I typically don't like manually disabling specific elements when it comes to Windows Updates.
And thanks for the reminder. I will be sure to run chkdsk as an additional preventative measure. I've also installed and ran CCleaner to help purge any bloat and temp files from the subsequent update cycles.
Thanks again to everyone for all the guidance and suggestions. Much appreciated!
