After installation of KB4056892 boot failure, after roll-back error 0x800f0845
2018-01-04T22:13:27+00:00
I have older AMD Athlon 64 X2 6000+, Asus MB, after installation of KB4056892 the system doesn't boot, it only shows the Windows logo without animation and nothing more. After several failed boots it do roll-back then it shows error 0x800f0845. Unfortunately, it seems it's not easy to disable the automatic updates without gpedit tweaks, so it tries installing and rolling-back the update over and over. The sfc /scannow shows no problem, in-place upgrade also doesn't seem to help. I can try full reinstall, but I doubt it will change anything. It seems like the update is binary incompatible with my old CPU. I understand that making the machine unbootable is the best protection from remote exploitation, but I would rather have the OS working. Especially if my CPU is not vulnerable to the Meltdown attack and the MS mitigation attempts for Spectre is more than questionable. I could find only some German and Italian people reporting the same issue (well the CPU is quite pre-historic and the KB update is very fresh), but no info / acknowledgment from the MS so far. I have Czech localization. Could anybody provide more information?
    2018-01-26T23:10:22+00:00
    On the newer  machine "check for updates"  does not offer KB4073290.
    I may not be interested in restoring AI Suite (I like the workaround) ,  still the question remains.
    Does KB4073290 fix other ( as yet not noticed) breakage caused by KB4056892?
    I don't think I am willing to risk possible damage by manually installing KB4073290.
    Like you said, we will probably have to wait until February to find out if KB4073290 is a companion or a replacement.
    Wandy_a
    I don't think you need to do anything, it seems as though your 32-bit machine is fixed by 4073291 and your newer 64-bit kit accepted 4056892 with minor "damage". Therefore you don't need 4073290 and that's why it's not shown as available in updates.
    I've had to do three resets after previous "updates" in the past year so I'm not too hopeful we're out of the woods yet. Tuesday, Tuesday...........
    Brian
    2018-01-27T02:48:22+00:00
    @BeastMstr
    I was able to re-activate Win 10 which was unbootable staying at the windows logo, same as you mentioned.
    My machine is an AMD Athlon 64 x2 5600+ with Windows 10 Pro, Version 1709
    I did the following:
    1.
    download the windows10.0-kb4073291-x86_898d588fa98a78fdb7f121f14b74f51df2a9416d.msu from Microsoft: https://www.catalog.update.microsoft.com/Search.aspx?q=windows%2010%201709%20cumulative%20update%20
    2.
    store the package onto the partition with the unbootable Win 10
    3.
    boot the machine into Windows 10 Repair Mode, Advanced Options, select Command Prompt
    4.
    execute the following:
    Dism /Image:C:\ /Add-Package /PackagePath:<path to the package>\windows10.0-kb4073291-x86_898d588fa98a78fdb7f121f14b74f51df2a9416d.msu /norestart /scratchdir:C:\Temp
    5.
    reboot
    Hope this helps
    Cheers Blubi
    Thanks Blubi, youre a star!  Different patch, kb4073291 for you, kb4073290 for us, but at least you have logged the correct procedure.  My partners PC is back up again using this process, she is a happy camper.  A few things to add - as not everybody would be comfortable with the command prompt.
    Firstly, for those reading this:
    Problem:
    AMD 4850e Athlon x2 based 64 bit system running Windows 10 received patch KB4056892 and would get to the WIN10 logo and effectively lockup.   Initially this could be resolved by rolling back to a restore point through the advanced recovery screens, until yesterday, when all the restore points were dropped.  This only left ONE rollback option, which had identical results, a hung WIN10 logo on startup - ie a loop to nowhere.
    Resolution #A:
    According to Microsoft..
    How to get this update
    This update will be downloaded and installed automatically from Windows Update. To get the standalone package for this update, go to the Microsoft Update Catalog website.
    With the former option being just fantastic if you are locked on a logo....  and the latter being the most minimalist fix description for a complete failure in coding that I have ever seen!
    They have disabled a customers operating system, the page should include a detailed procedure,  not just a download link.  I have to agree with a previous poster, as an IT specialist with over 30 years experience this ranks at close to #1 in the epic failures I have experienced!  I too would fire the IT dev department, and then sack whoever is managing customer liaison.
    Most disturbing is that many people are either not IT savvy, or only have access to a single machine.  I expect they would have (in desperation) gone through 'reset my PC' meaning a very temporary fix *maybe*, and the requirement to reload ALL applications, activation keys, profiles etc etc.
    Resolution #B:
    Some more details to the resolution process:
    Note that this which does nothing more than apply the kb4073290patch, there is no other system impact.
    Get onto another PC/Laptop and download that MSU file from the catalog from the update catalog
    Its around 600 MB so drop it onto a flash drive/memory key, or burn it to cd/dvd.
    Boot up your bricked machine
    If it goes to the locked WIN10 logo then reset it to boot again until it drops into repair/diagnosis
    advanced options > command prompt
    ..because i have some grey hair I know CMD as just a DOS emulator, others may not be so comfortable with this.
    Note if you want to copy paste (such as the long patch name..) then right hand click in the CMD top window header - select mark, highlight with the mouse, then right click in header and select copy, repeat the process to paste...
    insert your USB key (or whatever media you have chosen)
    from command prompt:
    go to the C drive - providing that is where you have installed Windows.
    Z:&gt;C: (Go to the C drive)
    C:&gt;cd ..   (if you are in a directory and need to drop back)
    C:&gt;md patch   (make a dir for this KB)
    C:&gt;md temp     (create another one for installing the KB)
    C:&gt;cd patch   (go there)
    C:\patch>dir e:  (find the MSU file, in my case e: is the USB drive, if you are not sure just keep checking D: E: F: etc until you find it)
    C:\patch>dir e:
    Volume in drive E has no label.
    Volume Serial Number is 0039-08C1
    *Directory of E:*
    27-Jan-18  01:14       632,139,610 windows10.0-kb4073290-x64_5119daced3c80d539e79cf52a5fb5bc9cea61eb8.msu
    (copy the patch from the USB, in my case e:,  to the folder you created)
    C:\patch>copy e:windows10.0-kb4073290-x64_5119daced3c80d539e79cf52a5fb5bc9cea61eb8.msu *
    C:\patch>dir  (should show the MSU file is there)
    ..then
    (use DISM to install the package - there is more info here if required:
    https://docs.microsoft.com/en-us/windows-hardware/manufacture/desktop/dism-operating-system-package-servicing-command-line-options)
    C:\patch> Dism /Image:C:\  /Add-Package /PackagePath:C:\patch\windows10.0-kb4073290-x64_5119daced3c80d539e79cf52a5fb5bc9cea61eb8.msu**/norestart /scratchdir:C:\Temp**
    Once that completes:
    C:\patch>exit
    Drop back through those advanced menus until you find power off.
    Then boot the machine up.
    Good luck, the patch worked fine for me.
    2018-01-27T03:27:10+00:00
    Brian
    Oh, darn, I don't know.  MELERIX's response (see above) makes sense.  Then again waiting until Tuesday would be prudent.  The problem is that I feel like that cat who was curious about what was in that walled off hole people kept  getting buckets from.  We all know what curiosity did to the cat.
    When you think about it only one of four things can happen.........
    KB4073290 will not install.
    KB4073290 installs and replaces KB4056892.
    KB4073290 installs and co exists with KB4056892.
    or.......................
    I will post the results after I restore from system image backup.
    Faint heart doesn't win fair princess.
    Faint heart is less likely to be eaten by dragon.
    2018-01-27T20:01:36+00:00
    Happy that help couple of windows 10 1709 fall  creator update.
    After I install that standalone KB4073290 I could not install netframe work 3.5 had to remove that KB4073290 then I finally got the netframe work it did install properly . I never really seen that many problem since jan 1 2018 cumulative update . I belive does problem is due to some old  processors.  And microsoft issued out that cumulative update  way to soon with out testing them . Cannot install KB4056892 standalone I guess I ll  just leave it on OS Build 16299.125 till they fix the windows update ,Microsoft better check that next windows 10 upgrade 1803 coming very soon,
    THAT SHOULD OF NEVER HAPPEN
    2018-01-28T00:19:07+00:00
    Very detailed procedure, thank you for the suggested fixes. I was able to download, copy to the OS drive, and successfully apply patch KB4073290. However, unfortunately, the issue I'm experiencing just boots to a black screen with mouse pointer. It's curious that I'm able to get to the Win10 login screen and see the various users listed. But as soon as I attempt to log into any of them, the dreaded black screen w/ mouse pointer is the only visual at this point. Going to keep searching for a fix on this. Any other additional suggested fixes would be appreciated. I'll also post back with any results of my own should I be successful in implementing something.
    EDIT: I also tried the same patch application method to implement KB4057144 without any success. Still searching for a remedy.
