After installation of KB4056892 boot failure, after roll-back error 0x800f0845
2018-01-04T22:13:27+00:00
I have older AMD Athlon 64 X2 6000+, Asus MB, after installation of KB4056892 the system doesn't boot, it only shows the Windows logo without animation and nothing more. After several failed boots it do roll-back then it shows error 0x800f0845. Unfortunately, it seems it's not easy to disable the automatic updates without gpedit tweaks, so it tries installing and rolling-back the update over and over. The sfc /scannow shows no problem, in-place upgrade also doesn't seem to help. I can try full reinstall, but I doubt it will change anything. It seems like the update is binary incompatible with my old CPU. I understand that making the machine unbootable is the best protection from remote exploitation, but I would rather have the OS working. Especially if my CPU is not vulnerable to the Meltdown attack and the MS mitigation attempts for Spectre is more than questionable. I could find only some German and Italian people reporting the same issue (well the CPU is quite pre-historic and the KB update is very fresh), but no info / acknowledgment from the MS so far. I have Czech localization. Could anybody provide more information?
    2018-01-17T20:40:20+00:00
    Here's a naive question:
    My computer is in an unbootable state and cannot do updates. It has an AMD Athlon 64 x2 microprocessor. Is the assumption that I have reinstalled Windows 10 and ripped out all my software and have been slogging through all the attempted restarts skipping KB4056892 all this time and now I'll reinstall one more time and then do the updates?
    I've been using another computer while watching this thread and hoping to hear an answer that involves a list of steps to take to take my computer from its unbootable state to a bootable state.
    One person suggests (after having success with this tactic) taking the boot HD out of the machine, plugging it into a (W10 compliant) machine with an Intel chip, booting up, then rolling back KB4056892 and saying no automatic updates. I can do that, but my question is, how confident can I be that Windows, when it sees my chip and motherboard and devices, will not take with it assumptions it got from booting up on some other machine, leading to problems?
    Others suggest making a recovery boot disk on another machine that is not crashed and booting up using that, then doing a rollback on the updates on the affected boot HD using command prompt commands. I'm worried about this because I was already theoretically able to do this from the command prompt in the Win10 diagnosis and recovery state, but the instructions given did not work.
    2018-01-17T20:41:34+00:00
    I installed KB4056892 (I didn't reboot the machine after install), then I installed KB4073290 over it, I rebooted twice (the second reboot probably wasn't needed, but Windows Update asked for it) and everything is OK. KB4073290 is shown as installed, KB4056892 isn't shown as installed and is not installed any more. So probably just installing KB4073290 is enough.
    2018-01-17T20:41:45+00:00
    Same problem with my i7 4770k..
    Any news on an update?
    2018-01-17T21:54:21+00:00
    From "Monkey57" I noticed that there is an update available:
    https://support.microsoft.com/en-us/help/4073290/unbootable-state-for-amd-devices-in-windows-10-version-1709
    I was a little bit worried that the link to http://www.catalog.update.microsoft.com/Search.aspx?q=KB4073290 would be unsafe.
    I decided to preceed and downloaded and installed the cumulative update on my AMD W10 machine. After an apparently succesful install I unblocked "Windows update" and the faulty package (which I had blocked according to preceding advice in this forum) did not reappear. Now all updates have been installed and the machine (re)boots normal. Watching the eventviewer is perhaps wise to monitor abnormalities.
    2018-01-17T22:39:56+00:00
    I too am having issues, similar with my older AMD processor.
    This all started at the beginning of the year
    I don't get STOP errors,  My issues manifest when I insert a USB the stick is not recognized.
    I reboot my computer to see if that helps and I get BSOD inaccessible boot device.
    upon restoring the latest restore point (from 1/10) I can eventually get windows back up and running
    but the issue happens again.
    Today I restored to my NYE restore point 1/1 before the patch install
    the wushowhide.digcab didn't see the KB4056892, so I couldn't hide it.
    in update install history I see KB4056892, installed on 1/7  but I know it is not.
    (my system was brought back to 1/1 via system restore). maybe that helps
    I disabled windows update, anyhoo
    fingers crossed.
