After installation of KB4056892 boot failure, after roll-back error 0x800f0845
2018-01-04T22:13:27+00:00
I have older AMD Athlon 64 X2 6000+, Asus MB, after installation of KB4056892 the system doesn't boot, it only shows the Windows logo without animation and nothing more. After several failed boots it do roll-back then it shows error 0x800f0845. Unfortunately, it seems it's not easy to disable the automatic updates without gpedit tweaks, so it tries installing and rolling-back the update over and over. The sfc /scannow shows no problem, in-place upgrade also doesn't seem to help. I can try full reinstall, but I doubt it will change anything. It seems like the update is binary incompatible with my old CPU. I understand that making the machine unbootable is the best protection from remote exploitation, but I would rather have the OS working. Especially if my CPU is not vulnerable to the Meltdown attack and the MS mitigation attempts for Spectre is more than questionable. I could find only some German and Italian people reporting the same issue (well the CPU is quite pre-historic and the KB update is very fresh), but no info / acknowledgment from the MS so far. I have Czech localization. Could anybody provide more information?
    2018-01-12T01:42:10+00:00
    MaroBeyUT - STOP! You post your answer ONCE. ONCE only. Those who want to see your reply will (via fhe little check box below the REPLY BOX where you check the box to "Notify me when someone response to this post.")                 I (and everyone else) have gotten 20 of your SAME ANSWER about "As I complained to Microsoft On line Help, they connected me to a technician .................." or the one about " Sorry I am new to the forum.  I did not know how to send one reply to all messages."                    So please STOP. And I agree with some of the others, not sure you understand what you are doing on this forum - or what you've done to your computer.
    2018-01-12T08:46:24+00:00
    Thanks Valdemar_Klausenburg_III for the information about AMD's prospective updates and a bit of history on AMD's performance, or lack of in 2007.
    Just as a bit of feedback  on the wushowhide.diagcab utility. It did not work for me as it saw other pending updates except KB4056892
    I am going to stop all updates on my BU AMD system until some further resolution is developed. Not ideal but needs must.
    2018-01-12T09:06:11+00:00
    I agree that AMD has terrible customer support, i.e. very similar to what MS has :) But as I wrote earlier Linux kernel patched according to similar instructions seems to boot OK on the affected machine. AFAIK at the moment there isn't publicly available microcode update for K8 CPUs, so maybe (just speculation) the Windows update brought updated microcode under NDA which was faulty? In such and similar cases AMD could be responsible for the problem, but primary responsibility is still on the MS to test the update before releasing.
    2018-01-12T11:40:15+00:00
    While I have plenty of workstations to test this ((JoeReedy's post ->"But appears to not be a problem."), I am kinda busy recovering lost systems.  I saw 2 systems relocked yesterday, before updates could be stopped..
    Did you tried this suggestion?
    Opteron185 replied on January 9, 2018 1/9/2018 8:11:49 PM (on page 18 of this same question)
    https://answers.microsoft.com/en-us/windows/forum/windows_10-update/after-installation-of-kb4056892-boot-failure-after/6c015632-2a45-4725-a882-f231f8c88f36?page=18#LastReply
    PS:
    Is there a way to link a specific post in this forum?
  5. Monkey57 3,535 Reputation points
    2018-01-12T12:30:22+00:00
    Different suggestions work for different machines.
    If a systems is able to self restore:
    If you are able to - use the Hide/Show troubleshooter to hide the Update, make sure you go into 'Control Panel-Programs&Features-view installed updates' and uninstall the update (as KB4056892 is usually awaiting a restart, if the Hide/Show troubleshooter finds it), before you reboot the system.
    "Is there a way to link a specific post in this forum?"->
    The way I do it is to click the link "Post a Reply" that it goes too from an email, then copy and paste the browser link, not the 'copy link' when right clicking in the email.
    Jssssssss is an expert at posting links, I will ask her, as my method only works in Subscribed threads from the point of subscription.
