After installation of KB4056892 boot failure, after roll-back error 0x800f0845
2018-01-04T22:13:27+00:00
I have older AMD Athlon 64 X2 6000+, Asus MB, after installation of KB4056892 the system doesn't boot, it only shows the Windows logo without animation and nothing more. After several failed boots it do roll-back then it shows error 0x800f0845. Unfortunately, it seems it's not easy to disable the automatic updates without gpedit tweaks, so it tries installing and rolling-back the update over and over. The sfc /scannow shows no problem, in-place upgrade also doesn't seem to help. I can try full reinstall, but I doubt it will change anything. It seems like the update is binary incompatible with my old CPU. I understand that making the machine unbootable is the best protection from remote exploitation, but I would rather have the OS working. Especially if my CPU is not vulnerable to the Meltdown attack and the MS mitigation attempts for Spectre is more than questionable. I could find only some German and Italian people reporting the same issue (well the CPU is quite pre-historic and the KB update is very fresh), but no info / acknowledgment from the MS so far. I have Czech localization. Could anybody provide more information?
  1. Deleted
    2018-01-12T00:57:46+00:00
    https://answers.microsoft.com/en-us/profile/5f0ae50f-f8f4-4baa-948f-0c527af42e3b
    MaroBeyUT
    Why are you posting this over and over?
    I don't believe any of this crap that Microsoft have told you.
    You didn't say that what you did has worked.
    Others have posted that installing a new copy of Windows 10 has not fixed the issue.
    In my case, my AMD computer that was made unbootable when trying to install this update was a brand new install of Windows 10 version 1709. In was not an upgrade from any previous version of Windows.
    2018-01-12T01:01:16+00:00
    It worked and the computer is running perfectly.  But I have to spend a lot of time now trying to install all the apps and relate them to their data.
    I have plenty of data on additional three hard drives.
    Some apps are no longer able to work on the new Windows-10 that MS Rep installed a fresh.
    2018-01-12T01:06:20+00:00
    MaroBeyUT
    Sorry I am new to the forum and tried replying to as many as I could.
    The solution I posted worked and if you are willing to do the same, I expect it will work as it did by the second level technician from Microsoft did to my computer.
    My computer has AMD X chip and is 32-bit because some Apps I have are old, since the 32-bit era (XP and 7).
    What is funny is why the previous too many updates workrd in presence of the same errors MS Lev-2 Technician said exist?
    Definitely in my personal opinion it is something that MS should not have created in this newest update of 2018-1
    2018-01-12T01:12:06+00:00
    MaroBeyUT
    Sorry.  I am new to this forum and tried maybe now I see it, not the best way.
    What I posted is exact description of what happened in my computer which was XP, then 7, 8, 8.1 and then Windows-10.
    What MS lev-2 technician did, WORKED and I am using the computer now and has restarted it already more than 8 times and am sending this reply from it.
