Thank you Sumit,
in the meantime, I am having to consider uninstalling the KB4056892 update on older Intel processored machines, if the user complains apps have not run right, recently (i.e. when running search/find functions within their long running Business specific programs they go outside for 5 min after initiating a search request).
I Don't think a complete reset of Windows Updates is necessary, nor do i think it would help in this situation, although I would probably start with a Disk Cleanup, before running a script which I would get here, if there was evidence it was beneficial in this situation. And not sure why the first step in your Linked website's 'Initial Instructions' is to download a PUP, please consider better ad placement on YOUR website.
Gianni1962 has had the best suggestions (IMO) (thank you sir):
How to exclude the Update:
- If possible in your Windows 10 version, set your connection as "metererd", this will stop automatic download of updates
- use the Hide/Show troubleshooter to hide the Update
- if the Update is not "waiting for restart" in Windows Update, you can restart the pc now
- if instead the Update is in the "waiting for restart" state, it is already listed in the uninstallable updates so you can uninstall it How to Uninstall a Windows Update in Windows 10 and then restart your pc
- wait some minutes and then check Windows Update to verify that the Update is now ignored
- reset your connection to not metered
AND
My (Gianni1962) approach is to wait for the resolution, if any will come.
In the meantime I have Hidden the update in the pc at risk.
Deactivating the Virtualization support in the BIOS, on some pc has permitted a normal boot.
After you have managed to successfully Hide the update, you can reactivate it.
As the MS Bulletin is Last Updated: 08-Jan-2018, and I have seen machine reset 2 days after the 8th, my confidence is low in that released statement.
And hope your machine remains stable, after it gets itself together/caught-up, after being off for a bit.
