Thanks, good info.
After installation of KB4056892 boot failure, after roll-back error 0x800f0845
I have older AMD Athlon 64 X2 6000+, Asus MB, after installation of KB4056892 the system doesn't boot, it only shows the Windows logo without animation and nothing more. After several failed boots it do roll-back then it shows error 0x800f0845. Unfortunately, it seems it's not easy to disable the automatic updates without gpedit tweaks, so it tries installing and rolling-back the update over and over. The sfc /scannow shows no problem, in-place upgrade also doesn't seem to help. I can try full reinstall, but I doubt it will change anything. It seems like the update is binary incompatible with my old CPU. I understand that making the machine unbootable is the best protection from remote exploitation, but I would rather have the OS working. Especially if my CPU is not vulnerable to the Meltdown attack and the MS mitigation attempts for Spectre is more than questionable. I could find only some German and Italian people reporting the same issue (well the CPU is quite pre-historic and the KB update is very fresh), but no info / acknowledgment from the MS so far. I have Czech localization. Could anybody provide more information?
2018-01-09T21:59:36+00:00 -
2018-01-09T23:04:07+00:00 After 20 years of computing Microsoft have managed to do what no hacker or virus have done to my computer - shut it down with a patch that was supposed to aid my computing experience. Is this like the Apple way of getting us older users to purchase a new machine (Apple slowing usage and not allowing updates to older machines)? My laptop was working perfectly until Tuesday 8th Jan 2018 but now it hangs at logo screen. Are Microsoft going to reply to this problem? Are they working on a fix? What are they going to do to compensate me for damaging my previously perfectly working laptop (an Acer Aspire 7520 with Athlon AMD 64 x 2 processor)? This is a massive problem and needs answers not silence.
2018-01-10T01:36:53+00:00 My intel cpu machine wont boot after the update.
But I get an animated logo for a bit then no boot device available.
Cant use USB to "upgrade" the installed version of windows because you must beable to boot into that version of windows for the upgrade to run
Safe mode does not work.
Can get to command prompt, and other repair options.
when restoring to restore point created by critical update (which I think fails because restore point does not go away) still cant boot {{ dont have patience to watch the system restore process}}
Any clues as to what to try with out a fresh new install ??
2018-01-10T02:12:06+00:00 My intell machine does not show a package installe on 1/6/2018 which is the date of the system restore point for the critical update.
My machine give no boot device after booting with animated logo for a several seconds the goes blue screen with error.
2018-01-10T02:32:48+00:00 I’m in the same boat (Athlon 64 X2 6000 on a Asus M2N-E motherboard). What i can’t figure out is how to prevent the updates. I have a restore point, which seems to work, but after the first reboot it immediately does some updates which borks the system, and I’m back to square one. How do I get the restored system to not do any updates?
I even downloaded an ISO of the Fall Creators Update, but my machine hangs when booting off of it (with a really weird orange screen).
