After installation of KB4056892 boot failure, after roll-back error 0x800f0845
2018-01-04T22:13:27+00:00
I have older AMD Athlon 64 X2 6000+, Asus MB, after installation of KB4056892 the system doesn't boot, it only shows the Windows logo without animation and nothing more. After several failed boots it do roll-back then it shows error 0x800f0845. Unfortunately, it seems it's not easy to disable the automatic updates without gpedit tweaks, so it tries installing and rolling-back the update over and over. The sfc /scannow shows no problem, in-place upgrade also doesn't seem to help. I can try full reinstall, but I doubt it will change anything. It seems like the update is binary incompatible with my old CPU. I understand that making the machine unbootable is the best protection from remote exploitation, but I would rather have the OS working. Especially if my CPU is not vulnerable to the Meltdown attack and the MS mitigation attempts for Spectre is more than questionable. I could find only some German and Italian people reporting the same issue (well the CPU is quite pre-historic and the KB update is very fresh), but no info / acknowledgment from the MS so far. I have Czech localization. Could anybody provide more information?
    2018-01-09T10:16:04+00:00
    That's a real shame that the patch didn't create a Restore Point !
    That's bad, really bad, Microsoft folks.
    2018-01-09T10:18:44+00:00
    2018-01-09T10:27:16+00:00
    No, it is not needed anymore!
    Windows operating system security update block for some AMD based devices
    "To prevent AMD customers from getting into an unbootable state, Microsoft will temporarily pause sending the following Windows operating system updates to devices with impacted AMD processors at this time:
    January 3, 2018—KB4056897 (Security-only update)
    January 9, 2018—KB4056894 (Monthly Rollup)
    January 3, 2018—KB4056888 (OS Build 10586.1356)
    January 3, 2018—KB4056892 (OS Build 16299.192)
    January 3, 2018—KB4056891 (OS Build 15063.850)
    January 3, 2018—KB4056890 (OS Build 14393.2007)
    January 3, 2018—KB4056898 (Security-only update)
    January 3, 2018—KB4056893 (OS Build 10240.17735)
    January 9, 2018—KB4056895 (Monthly Rollup)"
    I have read that, unfortunately, for those who are not in "this state" update was still occurring this morning. It was obviously my case (build 16299.125)
    So I recall what I have done to "block it manually" ;)
    Alex
    2018-01-09T10:30:28+00:00
    This is really good, but when i can't hide update in Windows 10 like in Windows 7 - it's not good....
    2018-01-09T10:43:59+00:00
    You should be able to hide/block it with a right click on the specific update while seeing the list (see picture as an example) + reboot
    control panel>> system and security >>windows update>> select updates to install
    https://cdn.makeuseof.com/wp-content/uploads/2016/02/Hide-Windows-10-Update-640x454.png
